6.0 engine
Old Jul 23, 2010 | 08:56 AM
koonhunter's Avatar
koonhunter
Question 6.0 engine
i have a 04 f 250 i was wandering if i could make the cooling fan run more, it seem to not run like it should when pulling a hill. just wanted to know if there is a kit to make the fan run more. thanks
Old Jul 23, 2010 | 09:29 AM
69cj's Avatar
69cj
The fan is controlled by the pcm and it is a modulated hall effect type of signal. If it is not functioning properly you need to determine the cause. The days of on/off power has left the barn.
Old Jul 23, 2010 | 10:09 AM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Oh and BTW, Welcome to FTE
Old Jul 23, 2010 | 10:28 AM
Cowboy65's Avatar
Cowboy65
If everything is working properly the factory set-up should keep your truck plenty cool. If the truck is running hot you should find out the root cause. Follows are a couple of recent threads that will provide some additional details on the operation of the fan and why it not a good idea to modify the controls. As 69cj explained there is much more to the operation of the fan than simply turning it on and off based on a thermostat.
https://www.ford-trucks.com/forums/9...oling-fan.html
https://www.ford-trucks.com/forums/9...de-switch.html
Old Jul 23, 2010 | 10:29 AM
tex25025's Avatar
tex25025
Well it might actually not need to run depending on what's going on when you are going up that hill. I haul around areas with a good bit of elevation, hauling significant amounts of weight, in areas that have pretty high ambient temps and my fan has only come on a handful of times.
I don't know what you exact situation is, but just based only on what you have typed, there might not be any reason for it to come on at all.
Old Jul 23, 2010 | 10:37 AM
02GrayPowerStroke
I guess a question I have is what are your H2o temps? My fan will not come on unitl my gauge reads 212ish
Old Jul 23, 2010 | 12:08 PM
Cowboy65's Avatar
Cowboy65
Keep in mind that engine temperature isn't the only parameter used by the PCM to determine fan operation. Most people see some variation in engine temperature vs fan operation.
Old Jul 23, 2010 | 12:10 PM
02GrayPowerStroke
What else does it use? OT or tranny temp? Or something?
Old Jul 23, 2010 | 12:24 PM
Cowboy65's Avatar
Cowboy65
The PCM uses ECT, transmission fluid temp, and intake air temp parameters to determine fan operation. A pulse width modulated signal is then output to a fluid port on the fan drive to regulate speed. The fan also has a hall effect sensor used to provide speed feedback to the PCM. As 69cj said before the days of simple fan operation are in our rear view mirror.
Old Jul 23, 2010 | 02:36 PM
koonhunter's Avatar
koonhunter
thanks guys it just started running hot when the temps got hot here in AL. some tell me that it should kick on and u should hear it roaring i have not heard it, it my son truck i am trying to see what wrong! i am in process of replacing egr cooler with a delete kit & took oil cooler off & clean it good not back together yet it just get hot when climing a long hill & thanks for the welcome & info.
Old Jul 23, 2010 | 07:41 PM
cheezit's Avatar
cheezit
ive been running between 185-204. my fan doesnt ever seem to come on.
Old Jul 23, 2010 | 08:57 PM
06silvercrew's Avatar
06silvercrew
welcome! If your that deep into the truck, it would be silly to not replace the oil cooler IMO. They are "relativley" inexpensive and can save you headache down the road.
Old Jul 24, 2010 | 06:09 AM
jdadamsjr's Avatar
jdadamsjr
on our 3rd Ex and 2nd 6oh, would guess we have heard the fan come on just a handful of times since the 1st 2002.... every time it scared the stuffings out of us
IIRC, it was usually sitting at a light in the Texus heat, with cars all around, and both ac's blasting... guess I play the audio books, radio, etc. loud enough when moving that we don't hear it !
Maybe having all the exhaust from others around it makes it hot enough to blast on for a few seconds and then it goes off just as quickly... and never stays on once we start moving...
Old Jul 24, 2010 | 09:05 AM
69cj's Avatar
69cj
I agree 100% about changing the oil cooler. They cannot be cleaned internally which is where the problem lies. If the truck is a late 04 build you might look into updating the stc fitting in the hpop system while there also.
Old Jul 24, 2010 | 09:33 AM
ehgeeray's Avatar
ehgeeray
I thought the stc fitting in the hpop system was not a problem until 2005?
