Ball Joint Question...
Old Jul 22, 2010 | 11:28 AM
quisp's Avatar
quisp
1988 F150 4x4 6ft bed
Can I replace the Bottom Ball joint driverside without removing the entire hub assembly?
Will the Axel Shaft/ U joint be in the way of the "C" clip removal, replacement?
Old Jul 22, 2010 | 01:10 PM
danr1's Avatar
danr1
No, you must remove the hub, spindle and axle shaft or you won't get the ball joints out.
You'll also replace both top and bottom ball joints at the same time.
Old Jul 22, 2010 | 01:55 PM
quisp's Avatar
quisp
Ok, guess I Got some work to do -Thanks again.
