rear diff, front diff, transfer case
Old Jul 22, 2010 | 09:43 AM
1_BIGMOFO's Avatar
1_BIGMOFO
My front and rear diff / transfer case need the fluids changed and I want to get my facts together so I can buy the right stuf and get it done.
I would like to know what I need (I know i am going ot buy everything from Ford but what to get and how much to get would be great info.
also im sure I can figure out where the fill plugs are on the diff's but any pics / help would be appreciated. Also im not sure exactly how to to the transfer case....
Thank you
Old Jul 22, 2010 | 10:01 AM
DSMMH's Avatar
DSMMH
Your owners manual will tell you what and how much you need.
Around 3 quarts of 75W-90 synthetic diff oil for the front. No drain plug. Either remove the cover to drain or suck it out with a vacuum pump. Fill plug on driver side of diff.
Around 4 quarts of 75W-130 synthetic diff oil for the rear. No drain plug. Either remove the cover to drain or suck it out with a vacuum pump. Fill plug on passenger side of diff.
Around 3 to 4 quarts of synthetic ATF for the transfer case. Both fill and drain plug are on the back of the Xfer case. Drain plug at the bottom and fil plug about half way up.
I used Royal Purple synthetic diff oil and Synchromax manual tranny fluid for the Xfer case.
If you use synthetic diff oils you do not have to add the 4oz bottle of limited slip additive.
DSMMH
Old Jul 22, 2010 | 10:40 AM
1_BIGMOFO's Avatar
1_BIGMOFO
thanks man, is there gaskets for the diff's or do I use black RTV?
Old Jul 22, 2010 | 12:21 PM
Cowboy65's Avatar
Cowboy65
Use black Permatex. I normally let everything set-up overnight before I refill with fluid. But that's just me.
Old Jul 22, 2010 | 01:08 PM
bpounds's Avatar
bpounds
The tech folder on the Superduty forum has links to good how-to info on all three of those items. Suggest you take a look.
I wouldn't get ANY of the supplies for this job from Ford. JMHO.
Old Jul 22, 2010 | 01:40 PM
DSMMH's Avatar
DSMMH
You can scrape the gasket and use a new OEM gasket.
or
You can use the Permatex black Right Stuff. I used this when I changed the fluid the first time. Bolted the cover on and filled her right up with fluid. Never had a leak.
My OEM covers are no in China and I now have the Mag-Hytech aluminum high capacity front and rear diff covers that have embedded O rings for seals. Sweet!
DSMMH
Old Jul 22, 2010 | 02:25 PM
bpounds's Avatar
bpounds
There are no gaskets on either diff. It is silicone from the factory.
Also, Permatex has a new silicone RTV sealant specifically intended for diff covers. I haven't used it yet, but that's what I would choose.
Old Jul 22, 2010 | 02:45 PM
Cowboy65's Avatar
Cowboy65
Links below for the how-to's Bill references. Keep in mind that the info shown on Guzzle's website is for a 2002 model year truck.
https://www.ford-trucks.com/forums/8...with-pics.html
Welcome to guzzle's Transfer Case Fluid Change Web Page
Welcome to guzzle's Rear Differential Maintenance Web Page
Welcome to guzzle's Front Differential Maintenance Web Page
Bill - Nice job on the write-up you posted. I tried to rep you, however I must first spread the love to others.
Old Jul 22, 2010 | 03:05 PM
smokersteve's Avatar
smokersteve
I used Amsoil for the diffs and transfercase. Once I had the new fluid in the sound was not as pronounced with 4X4
Old Jul 22, 2010 | 03:13 PM
amgpro2's Avatar
amgpro2
DSMMH
Hi DSMMH,
I have an automatic tranny and it states to use Mercon V ATF for the Xfer case. Can Synchromax manual tranny fluid be used or is it for 6.0's with manual trans?
Old Jul 22, 2010 | 05:26 PM
1_BIGMOFO's Avatar
1_BIGMOFO
I dod everything today!! Im siked!!
Front diff
Rear Diff
Transfer case
external transmission filter with housing
wooohooo!!! Thanks for the help guys!!!
Pridnjoy
Sep 19, 2013 04:56 PM
kawkx500
Nov 14, 2012 04:36 PM
super fly
Oct 17, 2012 02:07 PM
shawn47905
Feb 15, 2004 02:42 PM
dclarson
1997 - 2003 F150
Aug 19, 2003 08:17 AM
