Cowl Vacuum Plugs
Old Jul 22, 2010 | 07:50 AM
80FlareSide's Avatar
80FlareSide
Cowl Vacuum Plugs
Under the hood p by the cowl there are 3 places to connect vacuum lines to for various diagnostics. In my truck the 2 longer connectors have caps over them, but the shortest does not. Does anyone know if this is supposed to be uncovered or not?
Old Jul 22, 2010 | 07:53 AM
ctubutis's Avatar
ctubutis
You should not have any vacuum leaks anywhere; if you're missing a plug, get another.
Old Jul 22, 2010 | 08:50 AM
masseysbronco's Avatar
masseysbronco
Did the f100's have those vacuum trees, or just f150's? Mine doesn't have one, and I see no evidence that it ever did (81). It may have not needed it since it doesn't have a brake booster, and its a 300.
Old Jul 22, 2010 | 10:05 AM
phurst's Avatar
phurst
My 83 F100 has one.
Old Jul 22, 2010 | 02:02 PM
Archion's Avatar
Archion
Veteran: Marine Corps
If you dont, than probably no air, no power brakes etc, so no need for a vacum distribution tree since no vacum is needed in the truck.
Old Jul 22, 2010 | 09:46 PM
ctubutis's Avatar
ctubutis
^What Archion said^
My understanding is that those were installed on vehicles with AC and were used to get
vacuum into the cab for the HVAC controls.
Old Jul 22, 2010 | 09:54 PM
FordNFishinLover's Avatar
FordNFishinLover
Yep thats your vaccum tree. If you have one thats just sitting there open then hurry up and get a cap on er! Your truck will appreciate it and you will too lol.
Old Jul 23, 2010 | 12:44 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Originally Posted by ctubutis
^What Archion said^
Correct. If your HVAC (Heater - A/C controls) are non functional, this area is the first place to look.
Old Jul 23, 2010 | 01:47 PM
Rogue_Wulff's Avatar
Rogue_Wulff
While everything listed above is spot on, I do have to ask this. 2 of 3 are capped and 1 is open. If you mean capped in the way I think of capped, that means using a cap to block an open port. If so, that means there's no vacuum at this tree, so no need to worry about the open port.
