Injector Issue - Maybe
Old Jul 22, 2010 | 06:54 AM
BigPapi's Avatar
BigPapi
04 6.0 CC 4x4 SB with 105k miles.
When it's cold (the motor) and if I drive it within 5-10 minutes of cranking it up it has been running weird. I work about a mile from a freeway, so when I go to lunch it's not uncommon to just hop on it and shoot across town. When the truck is 'cold' and I get on the freeway (in OD pulling a slight grade) it will 'buck' (the only similar feeling is like a 5.4 I had when one of the coil packs was going out) if I give it just a little throttle (not enough to kick down). If I give it enough to kick down it runs fine in the lower gear (or at least it feels like it does). After driving it 5-10 miles it doesnt do it anymore.
Is this an injector going bad?
Replaced the fuel filters about 2k miles ago and just did an oil change about 200 miles ago. I was getting a WIF light, but I cleaned that out (and inside where the sensor is). I havent gotten the WIF light since.
This has happened for the last few tanks of fuel. I dont drive the truck every day, but at least twice a week.
Old Jul 22, 2010 | 08:07 AM
DSMMH's Avatar
DSMMH
I would put Seafoam in the oil and fuel per the directions on the can and switch to synthetic motor oil, if not already. See if that does not fix your problem before you go changing injectors. If you have no injector codes, then I suspect you may have the beginnings of minor injector "stiction" (burnt oil residue buildup on injector plunger) on a few injectors. Seafoam may or may not remove the residue but it will not hurt to try it first.
I have used Seafoam for years in everything. Currently I treat the motor oil and fuel in my VW Jetta TDI, ZO6, X, Scarab, etc. on a regular basis with Seafoam.
I have an 04 X 6.0L with Royal Purple synthetic 20W-50 oil and just did a 1500 mile trip from MD to MI and back. Before I left I put two cans of Seafoam in my fuel tank (44 gal tank) and 1.5 cans (24 oz.) in my oil. I had 6000 miles on the oil before I left for MI. I run my motor oil until I cannot read the level marks on the dipstick or 10,000 miles, whichever comes first. FYI - I have never not been able to read the dipstick marks before 10,000 miles.
And as you can see in my signature my X has significant mods which put more stress on the turbo, injectors and tranny. In 90,000 miles I have never had a turbo degrade or failure, a fuel injector "stiction" issue or tranny issue (I use RP synthetic ATF). I attribute that to RP lubricants and Seafoam.
Also, many injector repair shops use a mixture of Seafoam and diesel fuel or straight Seafoam to clean and test injectors after repair.
DSMMH
Old Jul 22, 2010 | 10:58 AM
BigPapi's Avatar
BigPapi
I will give that a try. I will switch to Synthetic at my next oil change. I havent been driving it because I didnt want to damage it. If I hit it with an obdII reader should it tell me if I have an injector issue?
Old Jul 22, 2010 | 11:22 AM
DSMMH's Avatar
DSMMH
When guys switched to synthetic oil, a lot of them reported that it starts easier and runs quieter. My X did.
Yeah, a good OBDII reader should pull any codes. However, if it is not an injector electrical problem, i.e. injector connector or FICM problem, it will not pop an injector code. So if you have oil "stiction" or fuel issues, it will not pop a code.
DSMMH
Old Jul 22, 2010 | 12:04 PM
BigPapi's Avatar
BigPapi
Thanks!
Old Jul 22, 2010 | 02:42 PM
geeride's Avatar
geeride
My truck has been doing the same thing. It was really noticeable while towing. I will try the seafoam and synthetic also. I am also going to clean my EGR.
Old Jul 23, 2010 | 07:31 AM
BigPapi's Avatar
BigPapi
Did this yesterday and so far so good. I will drive it again today to verify.
