explorer a/c problem
Old Jul 21, 2010 | 11:42 AM
samanthas1977's Avatar
samanthas1977
1998 explorer sport a/c stoped working this morning on blowing thru the defrost vents and just laytly started to idle high when stoped
Old Jul 21, 2010 | 01:16 PM
shorod's Avatar
shorod
Welcome to the forum!
I'm not sure if you are suggesting that the air no longer blows through the defrost vents, if it only blows through the defrost vents, and/or if the air is no longer cold.
Does the engine idle smoothly, just higher than usual, or is the idle rough? Does it seem less powerful than usual?
-Rod
Old Jul 21, 2010 | 02:13 PM
samanthas1977
it idles high and a lil rough the air is cold and only blows out the defrost vent
Old Jul 21, 2010 | 03:29 PM
Navyguns's Avatar
Navyguns
Look for a leaking vacuum line for the vent controls in the engine compartment. They can be chafed or cracked. Going to defrost is the default for the vent control door. A vacuum leak will also cause a rough idle.
Michael Moshier
2004 - 2008 F150
May 15, 2012 12:18 PM
fordpride
Jun 9, 2011 01:43 PM
maxtruck00
Feb 7, 2010 11:15 PM
RyanGar
Dec 12, 2008 04:38 PM
reberhardt
Nov 8, 2002 09:08 PM
