My 2000 7.3 went to missing and then died. Finally got it restarted and it idled great for awhile then died when I moved it. Found a ICP code and changed that and also changed the injector harnesses, valve cover gaskets, and the injector end connectors going to the valve cover gaskets because the connectors were broken.
Upon doing that it started very hard but when I finally got it started it idled great for about 4 hours. I could rev it up and it was smooth just like it was supposed to be. It also would start great. Problem solved right? Wrong! Went out on the road and within 10 miles it started to died out and miss and now it will not start. Puts out a lot of white smoke as I am trying to start it. Fuel filter was new about 1 month ago. Any ideas? Tell me what more info you need and thanks for any help you can give.
Forgot to tell you all that when I changed the injector/glow plug harness I also changed the glow plugs because I had the valve covers off and thought I might as well do it now.
