Winch size?
Old Jul 20, 2010 | 07:19 AM
RedLesPaul's Avatar
RedLesPaul
Winch size?
I have a 79 F150 4x4 that's been sitting in my driveway for about a year, while I've been doing some TLC on her. Well, the town is complaining now, and I need to move it into the garage. Since, she doesn't run at the moment and there's about a 2 inch difference from driveway (pea-gravel) to garage floor, I'm thinking pushing it in is not going to happen. Thinking of getting an inexpensive winch to mount (securely) to garage wall and pull it in.
With the truck in neutral, what size winch would I need?
Thanks.
Old Jul 20, 2010 | 07:47 AM
fellro86's Avatar
fellro86
hand push it to the door, then use a 2 ton come-along to pull it up, then hand push til the other tires get there, and then do the same. Otherwise, you can carefully push it in with another vehicle, just put something soft between the vehicles. I have used tires, but you have to be careful with positioning or you can cause damage.
Old Jul 20, 2010 | 07:56 AM
fordman400's Avatar
fordman400
I second that idea push to garage then use a come along. I pick up a 4ton at hardware store for $40 cheaper than a winch and works just as well.
Old Jul 20, 2010 | 10:23 AM
HIO Silver's Avatar
HIO Silver
It would be alot easier to push/roll if the tires have less "squish". Have you tried overinflating the tires for less rolling resistance?
Old Jul 20, 2010 | 09:04 PM
hasteranger's Avatar
hasteranger
I dunno how your garage is built but theres a pretty good chance you'd rip the mounting out of the wall. Your average modern home construction isn't going to withstand that kind of pulling pressure! if I were you I'd just push it forward, jack it up from inside the garage. slide it forward on the jack, set it down, and do the same for the rear. Or just offer a friend a 6 pack to help push it. it only took 3 of us to push my 78 up a set of trailer ramps and onto a 5th wheel trailer and I guarantee that was steeper than the step into your garage!
Old Jul 20, 2010 | 09:31 PM
fellro86's Avatar
fellro86
It isn't like it is dead weight, it is just a roller. I have done that with 2x4 walls before with no damage. You obviously have to mount it a bit better than just a few screws into the board...
