NEED HELP!!
Old Jul 20, 2010 | 12:07 AM
platinum_stroker01's Avatar
platinum_stroker01
Exclamation NEED HELP!!
i have a 01 f250 platinum edition fully stock and i want to fix it up before school starts again (mid august) im going to be a senior and i want it to be the beast in the lot. where do i start?
thanks
Old Jul 20, 2010 | 12:15 AM
big poppa's Avatar
big poppa
Get ahold of Platinum Pete here, he's the only one other than you now thats has that sweet platinum edition truck and his is smokin and welcome to FTE, stick around..
Old Jul 20, 2010 | 06:25 AM
megawatt00's Avatar
megawatt00
thanks
Welcome to FTE
When you say fix it up are you talking about mods? if so here are the basic performance mods that are usually done
Exhaust: the stock exhaust is restrictive a 4" turbo back system will open it up and give her a nice sound.
Intake: get rid of the stock system and go with a 6637 or something of the sort
Guages: Boost trans and pyro so you can monitor what is going on with your truck
Tuner: After all the above is done then add a tuner to your truck you will be amazed at how "alive" your rig will be. I have a DP Tuner but there are others Tony wildman PHP etc. Custom tuning is the way to go, much better than any of the off the shelf tuners that you can buy,
