Sponsored by: Real Truck
Headlight upgrade
Old Feb 11, 2003 | 10:45 AM
ECM's Avatar
ECM
Question Headlight upgrade
I have the XL trim (Cheap) headlights and would like to upgrade to the XLT and higher trim level lights. Does anyone know if this is a direct swap and what would be needed other that the headlight housings?
Old Feb 11, 2003 | 10:50 AM
JoeBoost's Avatar
JoeBoost
Headlight upgrade
As far as I know , or am aware , this should be a direct swap. I believe all you need is to get a set of the actual headlamps , and that should be it.....
Old Feb 11, 2003 | 10:59 AM
hookspacken's Avatar
hookspacken
Headlight upgrade
i didnt know there was a difference in headlights? what exactly is the difference?
Old Feb 11, 2003 | 12:07 PM
coachhomer's Avatar
coachhomer
Headlight upgrade
hey all, i didnt know there was a headlight upgrade. so you are saying that my 02 lariat has better headlights than say a 99 xlt?
thanksscott
Old Feb 11, 2003 | 12:32 PM
DCSpecial's Avatar
DCSpecial
Headlight upgrade
coachhomer, the headlights and turn signal lenses changed in '02. Take a look at these pics. Older Style and Newer Style
Hope this helps.
Old Feb 11, 2003 | 12:45 PM
ECM's Avatar
ECM
Headlight upgrade
The difference is that when the XL headlights go bad you have to replace the whole headlight. In the XLT and up you just replace the bulb and thats it.
Old Feb 11, 2003 | 12:46 PM
hookspacken
Headlight upgrade
I knew that they changed light desing in 02, but there is no difference between XL and XLT, correct?
Old Feb 11, 2003 | 01:22 PM
coachhomer's Avatar
coachhomer
Headlight upgrade
thanks dc, that makes sence.
scott
Old Feb 11, 2003 | 02:32 PM
JoeBoost's Avatar
JoeBoost
Headlight upgrade
Ya , in 02 that changed to the "jewel" type headlights...
Old Feb 11, 2003 | 04:01 PM
Yeti's Avatar
Yeti
Headlight upgrade
I thought a XL only had the old style rectangular head lights, not the "euro" type.
Like this
Old Feb 11, 2003 | 04:20 PM
DCSpecial's Avatar
DCSpecial
Headlight upgrade
Yeah, all years XLs headlights look like that. Good pic.
Old Feb 11, 2003 | 07:28 PM
ke6jcf's Avatar
ke6jcf
Headlight upgrade
If your talking about the XL rectangular lights with the grey bezel, yes you can install the euro lights they just screw right in. There is even a pig tail inside the light housing that lets the old ugly lights plug into the euro light socket. Ford figured all trucks would get the euros and supplied a pig tail for the cheapies... Go figure.
The swap out takes about ten minutes. Don't forget to get some clear corners to go woth the new lights.
Hope this is what you were looking for...
Doug
Old Feb 11, 2003 | 09:36 PM
4x4x4x4's Avatar
4x4x4x4
Headlight upgrade
[QUOTE]Originally posted by YETI
[B]I thought a XL only had the old style rectangular head lights, not the "euro" type.
Starting in 02,for less than $200 you can get the better headlights,chrome bumpers,and full size hubcaps in one package.
I know because that's how I optioned mine when I ordered it.
Old Feb 11, 2003 | 10:01 PM
ECM's Avatar
ECM
Headlight upgrade
Thanks Ke6jcf thats just what I was looking for. I think I'll shop around for the housings I bet they're expensive.
Old Feb 12, 2003 | 06:27 AM
ke6jcf's Avatar
ke6jcf
Headlight upgrade
I bought mine straight from the Ford dealer. I think they were around $275 for the both. Picked up the clear corners on EvilBay for only $15.00. Shop around, when you do get the lights try to get the '02 and obove they are a lot nicer than the older ones.
'99 - '03 will fit, but again the newer ones are clearer and I think they reflect the light better. Should tell ya one more thing, depends on where you live, the clear corners on mine are clear all the way around, the DOT apoved clear lights have an amber reflector that is on the side blinker. Look at a new truck and you'll see what I'm talking about. Some of those cowboy cops with nothing better to do than ruin your day will ticket you for the non DOT approved lights. Where I live I don't think they care everyone runs 'em. The DOT apporved lights are a little more expensive.
Good luck
Doug
