Almost Done with Upgrades!
New BD PCV Filter/Drain Kit:
New IPT Fuel Regulator Kit/New HPOP and Injectors
New Air Box
7.3L PSD with 310k miles
Really pleased with the work done at Diesel Tech in San Jacinto by Loren and Gilbert. Very professial shop. Highly recommend. BTW, thanks Steve for the tip on these guys.
Yeah, I wanted to keep the fuel economy which right now is btwn 17-18 mpg. I was afraid if I went with Stage II I would loose some of that????? Right now I am sitting on 172hp over stock (on paper). It would be interersting to run it on a dyno and see what it is really putting out. They also went through my differential (at my request) and found the nut was backed out almost all the way and my clutch plates were bad. Appartently that is what was causing my vibration when under tow and turning. They thought maybe on one of the fluid changes that non-syn oil was used, or they forgot to add the modifier??? I try to be real careful and only use one shop to do work on my X, but you cant stand there and watch what they do, so I guess it could have happened. Appreciate all your help Steve, Loren runs a real nice operation.
Yes, he does, and he's a nice guy to boot.
It's comforting to have a confident feeling when you take your rig in for surgery.
