Offroad & 4x4
death woble help
Old Jul 19, 2010 | 12:52 PM
77f250400's Avatar
77f250400
death woble help
were to start ok i have a 1980 f250 4x4 it hade trhe indpented front end we took that out put 4 in lift leafs and a danna 60 king pin and lifted the rear and put it all bac together and went for a drive we get around 30 km to 50 km and the dealth woble start i cant evin hold the steering wheel when its wobling and its all over the road almost to head on crashes becouse of the wobling now i have talk to some people and ive been told i need a pan track bar or pan hard bar what is it and what dose it do any input would be great so i can finsh this off and not die in a crash
Old Jul 19, 2010 | 02:54 PM
Prozon's Avatar
Prozon
You need a "trac" bar.
Have you done a shackle reversal in the process of the solid axle swap?
(Did you move the swing shackle to the rear of the front leaf springs?)
Either way, should help. There could be more to it too.
Old Jul 19, 2010 | 03:17 PM
77f250400's Avatar
77f250400
we put the lift leafs in an put the axle in never touched the shackles there are stablizing bar in it alose the truck was lifted 4 inches and using the stock steering
Old Jul 19, 2010 | 04:32 PM
alpha/omega's Avatar
alpha/omega
sounds like the kingpins either A- needs to be rebuilt or B- needs a little more preload on the springs.
What size tires?
Old Jul 19, 2010 | 04:44 PM
fatdan460's Avatar
fatdan460
my vote goes to a cracked frame, right along the steering box somewhere. that's what killed my 85. barely noticeable even up close with a good light source. check it out just for the hell of it. 80-83 have junk frames with speed holes and they seem to fail a lot.
Old Jul 19, 2010 | 05:57 PM
73 ford guy's Avatar
73 ford guy
Check kingpins for sure and like alpha says put more preload in them by putting in a couple 7/8 washers. Other than that check all steering rod ends having someone turn the tires from side to side while tires are on the ground. A big one is also having balanced tires. If theyre bigger than 36's I'd running balancing beads in the inside to balance them. Not a bad idea to change the leaf spring bushings as well. I had bad DW and I changed all of that and it fixed it so I didnt really pin point which exact one it was. Another helpful trick is to run Hydro assist steering as you will gain WAY better steering power but the ram acts like the best stabilizer you can get locking your wheels in a straight line. Nite and day difference after I installed mine and it cruises nice on the highway even with 44's...
Old Jul 20, 2010 | 10:13 AM
79Ford4x4's Avatar
79Ford4x4
If your still running the front swing shackle then yes, you do need a trac-bar. I had the death wobble with rebuilt kingpins and only 37's. Washer in the cap really helped alot.
Old Jul 20, 2010 | 04:39 PM
Prozon's Avatar
Prozon
Yeah everyone jumped for the kingpins, but without a trac bar your going to have a wobble.
Old Jul 22, 2010 | 07:38 AM
alpha/omega
I dont have a trac bar....
Old Jul 22, 2010 | 08:51 AM
73 ford guy
I got rid of mine on the front. Didn't do anything to help wobble.
Old Jul 23, 2010 | 03:08 AM
Prozon's Avatar
Prozon
Alpha are you running shackle reversal?
Old Jul 23, 2010 | 03:16 AM
fatdan460's Avatar
fatdan460
kris, 70's trucks had the shackle at the rear. ford didn't get stupid till 1980.
Old Jul 23, 2010 | 03:21 AM
Prozon's Avatar
Prozon
Wow. I didn't know that. I'd rep ya, but your a dick almost all the time so...
:flipoff:
Old Jul 25, 2010 | 02:01 PM
4bysnduallies's Avatar
4bysnduallies
put a steering stabilizer on it
Old Jul 27, 2010 | 12:46 PM
alpha/omega
^^^ great idea!
FAIL!
