'95 E4od front leak?
Old Jul 19, 2010 | 09:34 AM
TNScrambler's Avatar
TNScrambler
My cousin has a '95 F250 that was origonally a 5 speed truck and someone swapped in an automatic E4od.
since he's had the truck (couple months) it has leaked atf out the front of the trans. It leaks worse when he's been towing or running in reverse.
We both checked around and have been told that there was an updated pump and front seal for these trucks, trans has newer gray paint on it, so we thought best case scenario the front seal is messed up, so we bought the updated seal for $5 and pulled the unit and swapped it. While we had it out we went ahead and pulled the pan, everything looked really clean inside, but we went ahead and changed the filter while we were in there. Fluid looked great, and just a very small amount of metal shavings on the magnet.
Put it all back together and filled full of fluid etc... started dripping again just like before. Drove it, it did fine, shifted normal just like before. Got on the interstate and it blew all the transfluid out the front of trans. He pulled it over and we loaded it up on the trailer so we didn't damage it.
Think we should pull it back out and buy the updated pump and put that in, or????
Does this sound common to anyone?
what are yall's thoughts?
Thanks,
Justin
Old Jul 19, 2010 | 10:39 AM
drivembig's Avatar
drivembig
The problem is the torque converter. When the torque converter get hot it will expand and either start leaking itself or push on the front seal and cause it to leak. That is why it leaks worse after you have been towing, because it get hotter. I had the same problem with mine and the Torque Converter fixed it right up.
Go ahead and get a multi disc heavy duty converter. The oem sucks.
Old Jul 19, 2010 | 01:08 PM
Cuda_jim's Avatar
Cuda_jim
Latest viton material seal info:
Seal, Front, E4OD / 4R100 1989-up * Updated VITON Makco Transmission Parts
Be sure to check the TC for a groove worn into it from the seal. If it's worn.....the only thing that fixes it is a new TC.
If a new seal doesn't fix the problem and TC is OK the oil drain back passages might need to be opened up to prevent seal blow out. This may require a complete tear down.....I have not done this. Maybe others will jump in with more info.
Old Jul 20, 2010 | 12:41 PM
sneal's Avatar
sneal
Too old for this
if you know a machinist who knows how to use Belzonie and can turn it correctly, that might fix your TC prob, but I say get a new triple and be done.
mrp669
41
Jan 4, 2017 08:26 AM
IAcowboy60
Nov 8, 2015 09:19 AM
southtexasidi
145
Jan 31, 2013 06:40 PM
countrycar
Nov 21, 2012 07:16 PM
BlueOvalRage
Dec 3, 2010 08:15 PM
