Sponsored by: Auxito
Transmission trouble code ?
Old Jul 18, 2010 | 03:36 PM
fordguy4life's Avatar
fordguy4life
Anyone know if the "o/d off light flashing" fault codes can be read with a OBDII reader??? Or do you need a special scanner?
Old Jul 18, 2010 | 04:05 PM
projectSHO89's Avatar
projectSHO89
You need an OBDII scanner that supports "manufacturer-specific" codes, a feature usually not found in low-end and entry-level models. For a DIYer, a scanner that lists for around $150-200 or more will usually have this capability. See the scanner's specifications to see what it can do.
KCMAGERS
May 8, 2007 12:36 AM
Quantrex
Sep 2, 2002 06:53 PM
May 3, 2002 01:31 AM
TallPaul
Nov 15, 2001 05:38 AM
jowilker
Jan 28, 2000 03:52 PM
