liences plate lights
Old Jul 18, 2010 | 12:41 PM
nevets7's Avatar
nevets7
have a 97 explorer and the lights for the lience plate won't light up. the bulbs are good and i have 7.4 volts at both of the recepticals but no lights when bulbs are put in.
Old Jul 18, 2010 | 09:15 PM
shorod's Avatar
shorod
7.4 volts is REALLY low, should be battery voltage of more like 11.8-12.5 with the engine off and 13.8-14.4 with the engine running. I bet as soon as you put the bulbs in the voltage drops to nearly zero. It sounds like you have a corroded or bad connection somewhere, either in the power side or the ground. Do the parking light work fine? Was trailer wiring installed without using the pre-wired connector near the taillight?
-Rod
Old Sep 1, 2010 | 03:16 AM
nevets7's Avatar
nevets7
got the problem fixed bad ground computer crashed
