Heat in the cab
Old Jul 18, 2010 | 10:54 AM
WarOzz's Avatar
WarOzz
Heat in the cab
Hey guys I need some help. I just took our first real big trip in the truck, drove from southern Oregon up to the middle of Washington and then down the Washington/Oregon coast. Only problem I had on the whole trip was it the heat in the cab, mainly off the drivers side! It was like the heater was stuck on hot and blowing at full fan speed right at my feet. It was the worst when climbing under load... 6200 lb RV up an 8% grade with it being 90 degrees outside wasn't much fun!
I have checked all the heater connections etc and everything seems to be working properly, heater and AC both work fine. I am thinking this was heat off the exhaust but not sure. I know this was an engine swap truck when I got it, so my question is... is there some sort of heat shroud that might be missing and causing this heat? Honestly I am grasping at straws here, anyone got any ideas then I want to hear them!
Old Jul 18, 2010 | 11:05 AM
Rick Wallace's Avatar
Rick Wallace
Glad you had a good trip Ozz.. I think you may need a shut off valve on the heater hoses,air going past the heater core will funnell right down towards the floor,Mine did that till the heater core busted then I bypassed it for a while and the heat went away. Just an Idea
Old Jul 18, 2010 | 11:56 AM
WarOzz's Avatar
WarOzz
That's just might be it Rick. Going out to get the wifes truck finished up and out of my shop today so I can get mine in and start looking for a fix.
Old Jul 18, 2010 | 11:57 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
when you turn the a/c on,do you hear a really loud "thump!!" like it means it? its quite loud and very forceful,and will be coming from the passengers side feet area,up under the dash.
off topic:
"6200 lb RV up an 8% grade with it being 90 degrees outside wasn't much fun!"
did your engine fan kick on while hauling this in these temps? (nothing to do with you a/c problem.)
Old Jul 18, 2010 | 12:08 PM
WarOzz's Avatar
WarOzz
I haven't noticed a loud thump as you describe it. What is that??
Yea clutch fan was kicking in fine, hottest the truck ever hit was about 212 degrees then fan would kick on and cool her right down.
Old Jul 18, 2010 | 12:16 PM
FORDF250HDXLT
yeah ok.that's what i figured your problem was.
there's a trap door in the ducting there,that seals off the heater core.if that doesn't get closed,forget it.you'll have your a/c on full tilt,and still be cooked alive lol.
you need to make this door closes again.the most common problem is the hose that connects to the...........ahh.you know what.im sure i can find a thread,possibly with pics that can explain this even better than i can.......
hang on.
Old Jul 18, 2010 | 12:21 PM
Rick Wallace
YUP,YUP
Old Jul 18, 2010 | 12:25 PM
FORDF250HDXLT
heres one.no pics though dangit.
but this will get you on the path to success warozz:
https://www.ford-trucks.com/forums/8...ater-core.html
if it turns out to actually be the blend door itself.....well,your not hearing the thump of it close at all...i was just gunna say,if it no longer seals tight,you'd want to just bypass the heater core for the summer,or install a shut off.-a good mod in itself anyway.but it's likely you have a problem with just getting the thing to close,let alone a tight seal problem.
you'll see the problem soon enough.
ahh i found one.:
from another good thread that will help you:
https://www.ford-trucks.com/forums/8...rom-vents.html
i just got my a/c working yesterday warozz.one of the first things i listened for was that thump.was happy to hear it.very loud and distinct when you have a nice seal there.
Old Jul 18, 2010 | 12:57 PM
LCAM-01XA's Avatar
LCAM-01XA
Guys, there is a vacuum-controlled heater core bypass valve that can be installed, it's normally found on Rangers but our trucks can use it too - here's the article you need to read for this:
Heater Core Bypass
I did this mod a while back and noticed no improvements at all, but my blend door seals very very good, others with not so perfect seals have reported that A/C did actually get colder after the bypass valve was installed.
Old Jul 18, 2010 | 02:15 PM
WarOzz's Avatar
WarOzz
I kinda thought it might be something along these lines... thanks for the great links! First to identify and fix the problem then add the vacuum bypass valve!
Old Jul 18, 2010 | 02:24 PM
swooshcmk's Avatar
swooshcmk
Engine swap truck? Was the previous engine a gas EFI? My truck is using an EFI cab from an '88 and the ECU plug came through the drivers side firewall right by your left foot. If the ECU was pulled and the plug undone you'll have about a 1.25" wide by 5" tall hole through the firewall left over from the gasser EFI.
Old Jul 18, 2010 | 02:27 PM
WarOzz's Avatar
WarOzz
No it was a diesel, just the po blew it up.... cavitation and replaced it with another 7.3 out of an ambulance.
Old Jul 18, 2010 | 02:29 PM
kenpobuck's Avatar
kenpobuck
I have that same hole in my Bronco cab. It does let in a lot of manifold heat and at road speed it is a good blast. I would seal it but I used it to run some wireing thru.
Old Jul 18, 2010 | 02:32 PM
swooshcmk's Avatar
swooshcmk
lol, I used mine to run wire through as well, however when I redid all this stuff I ran 'em through a grommet so I could seal up the hole
it lets a lot of hot air in during summer and a lot of cold air in during winter
Old Jul 18, 2010 | 02:34 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Coolant does circulate through the heater core at all times when the engine is running.
There is a door in the heater that shuts air flow across the heater core to control the temperature that is probably leaking air.
But a shut off valve in the coolant lines does a much better job.
Also you may have a couple holes through the firewall for wires that have no grommets or the grommets are damaged, letting even more heat from the engine compartment in.
