IPR o-ring kit
Old Jul 19, 2010 | 09:11 AM
Talyn's Avatar
Talyn
Originally Posted by BlueMule
I sure hope IH prices are better than Clays. I'd hate to have to spend 45 bucks just to get the 4 rubber rings.
4 o-rings on an IPR?
Interesting.
I had 2 and a nylon backup.
Really curious about the hpop seals though. I have to do this myself, mine leaking bad.
Old Jul 19, 2010 | 09:12 AM
Talyn's Avatar
Talyn
The IH kit is probably just the o-rings, not the collar and tin nut.
thats why it is cheaper.
Old Jul 19, 2010 | 10:16 PM
Oversize's Avatar
Oversize
I was at IH today looking for the IPR o-rings and they said the old part number here was the correct one and had no record with the new part number. it was $19 if it was in stock,... which it wasnt,... and would be about a week before they got anymore unless Iwanted to pay special shipping.
Old Jul 19, 2010 | 10:18 PM
Oversize's Avatar
Oversize
Also there are 4 o-rings in the kit, the 3 on the IPR body and the 4th is the seal for the electrical connector.
Old Jul 20, 2010 | 06:18 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Rodney,
Carry a can of starting fluid, if it happens again give it a spray to get the motor spinning and be on your way...
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jul 20, 2010 | 01:04 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I bougth the IH kit and came with the o-rings, collar and the nut.
Old Jul 20, 2010 | 04:28 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Thats what i did when my IPR o-rings were dead and had to wait on the o-ring to be ordered... it went for 3 days before it finally died and would not restart at all even when it was cold or on starter fluid.
Rodney, It'd be nice if those stealth pumps had a remote IPR setup like the Termies have. I like where Joey put the IPR at on his now. it's very easy to get to.
Old Jul 20, 2010 | 07:52 PM
BlueMule's Avatar
BlueMule
Interesting.
Come on William. I knew what I was talking about so I thought you would too. I've got the original stealth pumps with 2 hpop's and 2 IPR's. I meant the 2 o-rings on the body of the valve, I doubt the split backup rings are bad and I've got extra spacers and tin nuts. So yeak, 4 new o-rings is all I need.
What's leaking on yours? The gasket between the pump body and the front cover, the seal between the reservoir and the front cover or the o-rings at the ends of the high pressure lines?
Old Jul 20, 2010 | 08:02 PM
BlueMule's Avatar
BlueMule
No! It has the same parts as the Ford kit. Ford stuff usually costs more just because the bend you over every chance they get'.
Years ago I went to get a cover for the fuel bowl and my friendly neighborhood Ford dealer wanted $42.xx, I bought one from IH for $7.42
When I put the D60 under the front I again went to Ford for the banjo bolts to attach the brake line to the cylinder. $13.00 EACH and they wanted to special order them. I aint been back since.
Old Jul 20, 2010 | 08:10 PM
BlueMule's Avatar
BlueMule
Me too, I went to IH today and 1825806C92 is still a valid part number and they have no idea what 9X-1484 is. They didn't have them in stock either but they'll be here on Thursday for $15.00. Of course I won't be able to pick them up because I have to go to Vermont to pick up a couple of little tractors.
Old Jul 20, 2010 | 08:14 PM
BlueMule's Avatar
BlueMule
Rodney,
Good idea! Thanks Jim. I never thought of that and I'm sure there is a can buried in the toolbox somewhere.
Old Jul 20, 2010 | 08:23 PM
BlueMule's Avatar
BlueMule
Man I wish it was that easy. I gotta remove the fuel system, the IC piping, the GPR and all the high pressure lines before I can even see the pumps and then I still hafta remove one of the intakes to get them out.
See the pumps?
Old Jul 20, 2010 | 08:41 PM
  #28
Action4478's Avatar
Action4478
See the pumps?
How do you keep the motor so clean ?...
Old Jul 20, 2010 | 08:56 PM
  #29
BlueMule's Avatar
BlueMule
That's an old picture, maybe I washed it just for the pic, I can't remember. Mostly I just keep it in the garage. I've put less than 2000 miles on it in the 2 years it's been here in NY. I think it's about to turn 153000.
Old Jul 21, 2010 | 08:07 PM
  #30
fordpride's Avatar
fordpride
I know i not loosing my mind
