Sponsored by: Kumho
should i worry or is this normal
Old Jul 17, 2010 | 05:51 PM
fordfinatic's Avatar
fordfinatic
1995 ford f350 just had an alignment, and then drove the truck on a trip and noticed slight outer tire camber. should i worry or is this normal for a long road trip. and the truck has 33x 12.50s bfg all terrains on it
Old Jul 17, 2010 | 08:17 PM
Opossum's Avatar
Opossum
"outer tire camber"? Do you mean that the top of the tire is further out then the bottum, that is positive camber and is bad.
Is it 4WD? Which front axle if so?
Old Jul 18, 2010 | 05:36 PM
fordfinatic
yea thats what i mean and if u look at the front tires from the front of the vehicle, its not noticeable. but when it was on the alignment machine everything looked good. yes it is 4wd and i believe its a dana 60
