Wiring Issues
Old Jul 16, 2010 | 10:39 PM
650's Avatar
650
Wiring Issues
I was putting my dash back together here and as I was testing some of the electrics in it as it went back together when I felt the main string of wires from the fan switch area to about the ignition area got hot. So I unwrapped the tape off it and started feeling wires. I figured out it is the red wire with a green stripe that goes to the ignition that was heating up. Also I found out while playing with it that it only heats up when the key is turned to the running position. So I messed around with the wires and could not find any faults with them, so I,m at a loss here as to why they are heating up. So I,ve got to ask if you all might have a diagnosis or do they just get this hot when the truck is running? Thanks for any input.
Old Jul 17, 2010 | 05:39 PM
650's Avatar
650
Does anyones red wire with a green tracer coming out of the ignition switch get hot when you turn the truck on?
Old Jul 18, 2010 | 11:36 AM
alans77crew's Avatar
alans77crew
I cant remember the color but there is a resistor wire for your ignition that goes through
Old Jul 18, 2010 | 11:45 AM
steponit's Avatar
steponit
There is a 46" length of Pink resistor wire wrapped up in that harness before it turns into Red/green wire.
Resistance creates heat.
