Tow?
Old Jul 16, 2010 | 07:21 AM
procraft's Avatar
procraft
4th Gear
Tow?
I have a 2004 Ranger with the 4.0, 4:10 and a factory trans cooler. I am towing about 1000lbs 250 miles on the interstate. Can I use over drive?
Thanks!
Old Jul 16, 2010 | 08:18 AM
afsigma21's Avatar
afsigma21
Just watch your tach.
If you are constantly changing gears, NO you cannot use OD
If you cruise in OD and it holds speed, then yes you can.
HEAT is the enemy and the constant shifting causes the heat. I have towed 2000lbs in my 2002 4.0 w/ 3.55 rears in OD on flat land, but as soon as I hit a hilly area I had to drop OD.
Old Jul 17, 2010 | 07:33 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
I like afsigma21's OD ideas on this.
This time of year, if you can do the tow in the cooler parts of the day, or at night, it'll help too.
Make sure the serp belt, tensioner, idler pully, coolant, cooling system radiator cap, water pump & tranny fluid condiition & level & engine oil is in top condition, the cooler & radiator fins are clean & if bugs are likely to be a problem on the tow, use a bug screen over the grll.
This might be a good time to consider a good quality synthetic crankcase & tranny fluid oil, if your in a really warm part of the country, or can't tow when it's cooler.
Air up the vehicle & trailer tires, including the spares!!!!
Make sure you have a jack & lug wrench that'll fit both.
Lube the trailer wheel bearings.
Check the differential lube level & lube condition.
More thoughts for cosideration.
Let us know how your tug goes.
Old Jul 17, 2010 | 10:06 AM
Old93junk's Avatar
Old93junk
On flat ground, yes..........as soon as hills or grades appear, lock out the OD.
Really, 1000lbs is a minor load to tow, but be kind to your trans. and keep it from working too hard.
Old Jul 17, 2010 | 02:11 PM
MikeB 88's Avatar
MikeB 88
If it's OK, I'll add to this thread. 2000 Ranger single cab with 2.5L and 5 speed manual trans. What would be the best U-Haul trailer to use. I have a son that may be moving from Tulsa,OK to Abilene, TX. in August. He'll only have is personal stuff and maybe a tool box. The ranger already has a receiver hitch on it.
