A/C problem
Old Jul 16, 2010 | 07:19 AM
tajon's Avatar
tajon
A/C problem
so my ac is inop. When I turn it on nothing, no compressor, nothing but hot air. So I tried charging it up and with the freon added it would kick on the compressor. So I think I'm in the clear but when I turn it off I hear a hissing noise from the passenger side rear tire. I look under the running board and there is air or maybe freon pissing out at a good pace. It doesn't take all but a few minutes without the freon bottle attached for the compressor to cut out. Now my question is how do I id which line is which and do I need to have those lines to the rear? can I bypass the rear section somehow or do I need to have them? Where can I get these lines if needed?
Old Jul 16, 2010 | 09:05 AM
Johnny Langton's Avatar
Johnny Langton
Sounds like you have a damaged rear evaporator line,or possibly(if you're lucky), a bad sealing O-Ring on one of the line couplers. The lines are available from several sources-you'll just need to isolate which one it is,and then go from there. You really need a vacuum pump to pull all of the moisture out of the system before recharging it post-repair. Moisture is highly corrosive in an A/C system, and will quickly kill the compressor and damage the condenser,etc if it's not removed before putting the system back into service.
JL
jllaco
18
May 30, 2013 11:57 AM
jllaco
May 24, 2013 11:27 PM
d5332
1997 - 2003 F150
Nov 30, 2010 09:40 PM
G Ford Fan
Aug 18, 2010 03:59 PM
dogbite32
Aerostar
Jul 25, 2001 10:31 AM
