Sponsored by: Real Truck
5th wheel hitch
Old Jul 15, 2010 | 07:37 PM
frozenpoet's Avatar
frozenpoet
5th wheel hitch
So I just bought an older 5th wheel, it's not a huge one and I believe its dry weight is a little under 5500 lbs. Normally I would say to buy the best hitch I could afford but paying close to a grand for some of these seems a bit of overkill. My truck has the 5.4 so its not like I'm going to get a bigger 5th, with this truck anyway. My problem is I really don't know anything about the hitches, so what are some of your thoughts? Any brands that are good, or that I should stay away from? Is a sub $500 hitch worth it?
Thanks,
jeremyjeremy
Old Jul 15, 2010 | 08:42 PM
senix's Avatar
senix
Don't cheap out...Reese, pull-rite are pretty good brands.
Did you find a data plate on the trailer to confirm the weights?
Look at the king pin/Box on the 5 er. Most of them have a min hitch requirement stamped or labeled.
Old Jul 15, 2010 | 09:06 PM
RV_Tech's Avatar
RV_Tech
Some of the distributors have hitches on sale this summer. Shop around.
Steve
Old Jul 15, 2010 | 09:13 PM
Grodyman's Avatar
Grodyman
Look at the Curt, pretty inexpensive. I had the cheapest Draw Tite (Reese) 15K hitch, the Trail Boss, for a 98 Tahoe 22' 5th wheel on an F150, worked great. For $250 you can order a Reese No Drill custom bracket kit and install yourself in a couple hours, I just did it, works great. No holes drilled in truck frame, only in bed for rail attachment.
Gman
Old Jul 15, 2010 | 09:17 PM
no1glfhk's Avatar
no1glfhk
where are you from frozenpoet? i have a reese 15k fifth wheel hitch with the bed rails and brackets for sale.
Old Jul 15, 2010 | 09:35 PM
frozenpoet's Avatar
frozenpoet
I'm in va, the camper is currently sitting on a lot in Ohio about an hour or so Northwest of Pittsburgh, pa
Old Jul 17, 2010 | 01:48 PM
no1glfhk's Avatar
no1glfhk
i'm in michigan. i bit too far for youto travel for a hitch i'm guessing lol
Old Jul 17, 2010 | 07:26 PM
SDTriton250's Avatar
SDTriton250
I have a 14 year old Reese 15k non tilting hitch in our F250 with 5.4L to tow our 8500 lb 5th wheel. All 5th wheel hitches that I've seen will work within their ratings. I like the standard Reese, Curt, Drawtite two jaw non tilting hitch. Just my humble opinion...
cowmilker08
May 26, 2014 12:46 PM
Budlight592
6.7L Power Stroke Diesel
15
Dec 31, 2011 05:17 PM
stroker870
17
May 7, 2011 07:16 AM
Vinford
All Things Towing
Dec 22, 2009 09:40 PM
scottm1
All Things Towing
Feb 15, 2009 07:14 PM
