DP 80E Tune
Old Jul 15, 2010 | 02:23 PM
overthehillbill's Avatar
overthehillbill
DP 80E Tune
I am new to the wonderful world of DP tuning. My question now is: How does your fuel mileage compare using the 80e to stock? I have read that some folks have gotten better mileage using the 80e tune over stock.
Bill
Old Jul 15, 2010 | 03:32 PM
rbaker6336's Avatar
rbaker6336
Running on the mountain roads of N Georgia my milage is considerably better in 80E than stock
Old Jul 15, 2010 | 03:46 PM
bama29fan's Avatar
bama29fan
i see you dont have the 60E but do you think it would get even better than the 80E? How does the 40T compare the the 80E...milage wise
Old Jul 15, 2010 | 03:58 PM
rbaker6336's Avatar
rbaker6336
The 40T don't pull the hills quite as good as 80E.Seems the advantage is having enough power to pull the grades without downshifting.
On the open roads the mileage in 40T and 80E are bout the same
Old Jul 15, 2010 | 04:04 PM
overthehillbill
I got the tuner when John Wood rebuilt the tranny and I let him tell me what I needed. He said that for my use there is little difference between the 60 and 80. After meeting him and being able to hang in his shop for the day figured out real fast that this guy knows more about 7.3's then just about anyone on this planet.
Old Jul 15, 2010 | 04:11 PM
DieselCamper01's Avatar
DieselCamper01
I get slightly better in 80E than stock also
Old Jul 15, 2010 | 05:11 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
I get 1- 1 and a half mpg better in 80e.
Old Jul 15, 2010 | 07:15 PM
Orezona's Avatar
Orezona
The original purpose of 80E was for in-town stop and go daily driving. Not highway use. Thus the early low rpm shifts.
*JMO
Old Jul 15, 2010 | 07:23 PM
rbaker6336's Avatar
rbaker6336
Both of my tunes are in overdrive at the same RPM.40T shifts earlier than 80E in the lower gears
Old Jul 15, 2010 | 07:46 PM
overthehillbill
Thanks for all the info. The reason I ask is my overhead display reads between 24 and 26 mpg. Prior to the chip install, cruising at 2000 rpm it would read between 18 and 19 which was close to hand calc. I know it's called a lie-o-meter and it now tells bigger lies. Just wondering how the chip affects the display.
Bill
Old Jul 15, 2010 | 08:15 PM
Orezona's Avatar
Orezona
Mmm. That seems backwards to me. I prefer and expect my tow tunes to hold longer between shifts and shift firmer. Cause they are, tow tunes.
*Again, JMHO
Old Jul 15, 2010 | 10:04 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
My 60T winds out to much higher RPMs than my 60E or 80E.
I do get better mileage with the 80E in town and highway too. On flat highway I'll drop to 60E, but haven't had it long enough to see if that gives any better mileage.
Old Jul 15, 2010 | 10:28 PM
Franko72's Avatar
Franko72
Molon Labe
*JMO
I feel the same, in 80 econ I really have to put my foot into it to get a downshift at highway speeds.
I generally run in 80 tow on the open road, it tends to downshift easier.
Just my .02
ReugularGuyBob
13
Jun 6, 2015 03:53 PM
1L243
21
Apr 8, 2013 06:32 PM
hdman6
15
Feb 15, 2007 02:54 PM
blue02gt
17
Feb 6, 2007 11:30 PM
crack
Nov 8, 2006 12:27 PM
