Can't identify random hose
Old Jul 15, 2010 | 11:20 AM
jchosler's Avatar
jchosler
I can't seem to identify the little white plastic hose on the left side of the pic. It appears to have rotted awat and the assembly is connectoed to an arm on the passenger side fender. Anyone know what this is?
Old Jul 15, 2010 | 11:23 AM
thebig350's Avatar
thebig350
Vacuum line for the vent door actuator??
Old Jul 15, 2010 | 11:31 AM
jchosler's Avatar
jchosler
Is it crutial? what is it's purpose?
Old Jul 15, 2010 | 11:43 AM
thebig350's Avatar
thebig350
Well, there's another that's under the dash on the passenger side, that one controls the air routing in the cab to either blow from the dash vents or up down to the floor vents (i believe). The actuator under the hood is the door for a/c or vent, although i could be mistake. Perhaps somebody else could confirm or correct me, but i'm fairly certain that's it. Run through all the positions for your ventillation system, i.e., hot/cold, up/down, ac/vent, reg ac/max ac.
Old Jul 15, 2010 | 11:45 AM
jchosler's Avatar
jchosler
Could that be the reason my AC's not working?
Old Jul 15, 2010 | 11:51 AM
thebig350's Avatar
thebig350
It's possible, when you turn your ac on, does air come out of the vents or no? If your ac clutch is turning and your system is charged, it's entirely possible that is your culprit. If you run your ac for a while, do you have any condensation build up?? You'd be able to tell because water would be dripping from under the right wheel well. If the door is not actuating to route the air properly, you won't get it in the cab.
Old Jul 15, 2010 | 12:01 PM
Talyn's Avatar
Talyn
That hose is part of the blend door operations, I'm not 100% sure on that though.
Because the blend door is cable driven as well.
If you have a vacuum leak, your climate controls will be stuck on defrost vent.
Just an FYI there.
I'll trace it for you and take a picture so you can repair it.
To bad older vehicles rely so much on vacuums.
Old Jul 15, 2010 | 12:16 PM
jchosler's Avatar
jchosler
Just an FYI there.
Thanks William,
I havent notice any condensation build up and all my heater switches seem to work
Old Jul 15, 2010 | 12:31 PM
thebig350's Avatar
thebig350
How does you vent system work right now? What positions/settings are not working?
Old Jul 15, 2010 | 02:35 PM
jchosler's Avatar
jchosler
It's all working except the AC doesn't activate
Old Jul 15, 2010 | 02:44 PM
chicagodragon's Avatar
chicagodragon
that hose in your picture is for the fresh air vent. with t it broken like that you will be pulling in outside or engine compartment air.
Old Jul 15, 2010 | 04:26 PM
thebig350's Avatar
thebig350
When you say the ac doesn't activate, do you mean it does not blow cold air, or that the clutch is not turning on the compressor??
Old Jul 15, 2010 | 04:29 PM
jchosler's Avatar
jchosler
The clutch doesn't activate, I think I have 2 problems here
Old Jul 15, 2010 | 06:42 PM
Talyn's Avatar
Talyn
I'm quite ... educated on the AC working here after my recent clutch failure.
They say some systems wont engage if the system is not full either.
Not sure there, since its electronic actuated for the clutch.
Could be a sensor that is checking for it.
can you free spin the clutch with the truck off?
When the truck is on and on AC mode, does the clutch lock up and spin then? or does it drag? or attempt to lock up and not spin?
You can test the magneto on the clutch by pulling the connector directly behind it and jumping each pin to the battery. one to positive and one to negative.
It will engage the clutch, since its just an electromagnet.
If you get it to engage, and it still spins, you might just need to change the shims inside.
Which in this case is probably that the clutch is wore enough that the shim is preventing engagement, in that case remove the shim and reinstall the clutch.
its a 10mm socket.
Old Jul 15, 2010 | 06:44 PM
Talyn's Avatar
Talyn
By fresh air vent i'm sure your talking about for max ac and just AC.
Max AC pulls air from inside the cab, and AC pulls from the cowel.
With that broken. I'm sure it will stick on Cowel only.
Thanks for the info George.
