Base timing
Old Jul 15, 2010 | 08:50 AM
Richie.Rich's Avatar
Richie.Rich
Base timing
I have a 1992 with a 351. How do I get into base timing. I had to replace the lower intake and pull that dist and It's time to get it running and set timing. Any help would be awesome.
Old Jul 15, 2010 | 09:07 AM
lew52's Avatar
lew52
If you marked where the dist before you removed it just drop it back in the same place , remove the spout plug , & set the base timing to 10 deg BTDC , if not you need to turn the motor over to TDC on the compression stroke then drop it in so the rotor is pointing at the #1 wire on the cap ....Lew
Old Jul 15, 2010 | 09:33 AM
Richie.Rich
thanks! I have it marked i just don't know where the spout connector is located.
Old Jul 15, 2010 | 09:40 AM
lew52's Avatar
lew52
Mines on the drivers side fender well by the brake booster , gray or white plug...
Old Jul 15, 2010 | 10:19 AM
rla2005's Avatar
rla2005
A picture from Subford:
Old Jul 21, 2010 | 09:17 AM
nmgonzo's Avatar
nmgonzo
No wonder I had carbon build up in two of my spark plugs and it idled fine but pinged all over the place.
My spout connector is missing the cap.
Can I just cap it with some steel or copper wire??
Old Jul 21, 2010 | 10:06 AM
rla2005's Avatar
rla2005
Copper wire works too
