Sponsored by: Innova
Navigator front speakers
Old Jul 15, 2010 | 06:56 AM
illgorhythm's Avatar
illgorhythm
I have a 99 navigator, the drivers side front speaker is cutting in and out like theres a loose wire. I cant seem to get the grill off to check it, do I have to take off the whole door panel? If so has anyone done this and know the best way to go about it? Thanks!
Old Jul 17, 2010 | 08:36 AM
ReAX's Avatar
ReAX
Usually yes. Door panels are typically held on by 2-3 screws and some kind of clip. Pull up the window switch panel, any reflectors, and look in the door handle area for screws. Once you have two out and are pretty sure there isn't a third, try lifting up on the panel. Around 99 ford went to a lift up and pull out system over the old push pin door retainers. If it doesn't lift out, pull a corner back enough to see the retaining mechanism.
pilot4net
Jan 16, 2020 10:19 AM
BIGTRUCKBIGRV
May 3, 2014 10:33 PM
rettus72
2009 - 2014 F150
Oct 21, 2012 09:08 AM
illgorhythm
Jul 15, 2010 11:38 PM
s2gordon
Dec 15, 2005 09:36 PM
