Timing Chain options
Old Jul 15, 2010 | 01:31 AM
895.0f-150's Avatar
895.0f-150
A few days ago i decided to replace the water pump on my 89 5.0 its the original water pump and getting tired, but 20 years of corrosion ended with me using a chisel to crack the timing cover surrounding one of the bolts going to the block, a few other bolts broke off in the cover so no biggy. While i have the timing cover off im going to check it for slop...but if it needs replacing im lost on choosing a brand. Anyone have a particular timing chain and gear set band that they favor? im a little hesitant about obtaining one from autozone or something like that
Old Jul 15, 2010 | 01:48 AM
Opossum's Avatar
Opossum
Just about all good aftermarket timing chains are just re-boxed and marked up Cloyes units, so just get yourself the right Cloyes and save yourself the money, they make really good stuff.
Old Jul 15, 2010 | 01:51 AM
truckrider814's Avatar
truckrider814
Just make sure you get the double chained and gears big step up from the stock single chain makes sooo much of a difference, atleast it did for me made my response much quicker.
Old Jul 15, 2010 | 02:04 AM
Opossum's Avatar
Opossum
Ohh yeah and while your at it you may want to do some research on your cam and you may want to advance your cam a couple of degrees, generally that will give you some more low end grunt with these emissions cams.
Old Jul 15, 2010 | 07:41 PM
ac700wildcat's Avatar
ac700wildcat
I got the cheaper Ford Racing set from Summit. Think it was around $70. Seemed to be of good quality and works just fine.
Old Jul 15, 2010 | 11:43 PM
895.0f-150's Avatar
895.0f-150
thanks guys, now can someone walk me through reinstalling the timing cover...my haynes does just fine but id like to know as much as i can before hand. I've just recently replaced the oil pan gasket with the Fel-Pro one peice...what a pain.
