In Cab Caddy Organizer-With Rifle Rack.
Does anyone have one of these (D8TZ1046100B .. In Cab Caddy Organizer-With Rifle Rack)? I have been looking for one for my '80 regular cab for a while, but I've never even seen one. A picture and measurements would be really helpful, the one in the sales brochure is pretty small. Seeing as they are obsolete I was thinking of making something similar. Thanks!
Don't know if there is a difference between 80-81 but the '81 sales brochure shows rifle. Realistically rifle or fishin' pole, rack should work for either, or if you feel like a multi-course meal-BOTH! lol. AUBURN MOTOR SALES in Auburn IN was supposed to have the one with rifle rack but it turns out its the one without (D8TZ1046100A). You might be in luck 81-f-150! If you buy it post some pics for me...
It must be like the Power Mirrors.It's definitely up there with the rarest options.Power Mirrors,Behind Seat Organizer,and CB are some of the rarest options i've never seen.I've seen a few CB setups for the 73-79 trucks,but only one for the 80-86,none of which have been in a truck.It's hard enough for me to find a working Underhood light.Most of my junkyards have nothing but Customs and XL's in them,and the higher trim trucks are just standard optioned with no special options.
I have found 2 underhood storage boxes (1 with broken latch) and 3 underhood retractable lights (none in excellent shape, hope to build 1 good one). My 81 needs a "custom" centre dash ( mine has been chopped). I also have an aftermarket antenna on my '81, and I don't see the 4 screw holes for the factory style. This is the second truck I've seen like this. Did they use different antennas sometimes? Unless these trucks were radio delete orig. Seems unlikely as one is an explorer.
My truck was originally a Custom.It was Radio Delete though,so the bezel didn't have the holes for a Radio.One of my buddies cut it open when I let him have it,but then I ended up with it again.
My Original Cowl Panel doesn't have a hole or anything for the antenna.When I swapped to an 87-91 cowl panel,I got one with the antenna holes so I could have a radio.
Yep.It had everything for a radio Except the bezel,speaker wire harness,and holes in the doors/cab and cowl.What's even worse,is my truck was ordered and built in California,and doesn't have A/C either.
I put in the speaker harness,Antenna,Radio Bezel,and holes in the doors/cab so now the truck is ready for a radio.I also converted to newer style plugs because the rubber plugs suck and are a pain to get apart when they're older.What I plan to do is have a dummy Shaft Style Radio in the dash,and have a hidden modern CD Player with remote behind or under the seat in a special box so I can have modern conveniences but a factory look.
on
So a Ranger Lariat did not come with a radio as standard, you had to order it as an optional extra.
Would like to see another 1981 Explorer, any pics? Explorers were a limited edition trim and options package that did not feature in the main sales brochure. Fortunately I have the 1981 Explorer Brochure and you can see it here...
http://i447.photobucket.com/albums/q...scan0001-2.jpg
http://i447.photobucket.com/albums/q...scan0002-7.jpg
on
It's the same one that was used in the 1973-1979 trucks as well. Even the 1967-1972 had a version with the optional in cab gas tank delete option.
I've also turned up plenty of seats looking for that caddy.
![Smilie](images/smilies/happy0161.gif)
