Sponsored by: Real Truck
Throttle sticking at first press
Old Jul 14, 2010 | 04:14 PM
CrewCabInKenmore's Avatar
CrewCabInKenmore
I have a 2000 F250 Superduty with the V10. The throttle would stick when first pressed from idle, then be fine. Over time it got worse. Took it in the my local Ford truck shop, and had the throttle body cleaned. Everything was nice and smooth again. Now that I have 1200 or so miles after the cleaning, the sticking is beginning to return.
When the engine is off, the throttle plate moves smooth as silk, no obstructions and it looks clean. When the engine is running, there is that slight "stiction" when first pressing the pedal. It happens when revving from idle by hand under the hood as well. I am suspecting that it is not the cable or any assembly from the pedal to the throttle body, but rather something in or connected to the throttle body itself.
Would the IAC, MAF or other component cause this? It doesn't appear to be the physical parts up to and including the throttle plate assembly itself. What else kicks into effect when the engine is running and is connected to the throttle plate assembly?
Old Jul 14, 2010 | 04:18 PM
CrewCabInKenmore
Just thought for a second. Would the TPS put pressure against the throttle as a method determining throttle position? And only when the engine was running? (Thus the smooth plate motion when not running?)
Old Jul 14, 2010 | 05:52 PM
redford's Avatar
redford
FTE Leadership Emeritus
IAC might be a good guess. I'd clean it up and see if things don't change for you.
TPS is kind of doubtful, but if it is hanging up it would create a rough spot.
Old Jul 14, 2010 | 06:33 PM
CrewCabInKenmore
If feels like a rough spot right at the beginning when you first apply pressure on the pedal, then it breaks free. No odd idle issues or failure to return to idle afterward.
My mileage is just passing 105K, and I'll be taking it in for plugs after the next trip. I'll see if I can convince them to clean up the IAC again while they're tinkering in the neighborhood of the top end, since they just cleaned the throttle body a few months ago. Maybe replace it if they find something amiss. They're a good shop and have treated me well. So far the worst I've had to deal with has been ball joints (just love the greaseless ones... not!), brake rotor wear causing issues more often than I'd like (I know it needs surfacing when downhill grades start vibrating a little), and some rough idling when I first got it new.
