86 F-150 Overheating
Old Jul 14, 2010 | 12:20 AM
RA101325's Avatar
RA101325
Banned
351 Windsor overheating after a few minutes of running. Replaced the water pump, fan and fan clutch, thermostat, radiator, and fluid. Still overheats after only a few minutes. Any ideas???
Old Jul 14, 2010 | 04:00 AM
Ken Blythen's Avatar
Ken Blythen
Are you sure that it has the correct rotation fan?
Serpentine belt equipped engines had opposite fan rotation to regular v-belt equipped. If it is wrong, the fan is fighting the airflow when traveling, so no cooling.
Both the fan, & your forward motion, should be bringing air BACK through the radiator.
The fan clutches also are made in both clockwise & anti-clockwise rotation versions, so need to match the fan & engine.
Old Jul 14, 2010 | 08:36 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Same with the water pump ...
Is it leaking combustion gases into the radiator, they have test kits to check for this.
-Enjoy
fh : )_~
Old Jul 30, 2010 | 07:00 AM
Ken Blythen
Any further ahead?
Old Jul 30, 2010 | 05:46 PM
RA101325's Avatar
RA101325
Banned
It appears to have been air in the engine. I bled it once, but apparently not enough. Did a thorough bleed and it seems to be resolved. Now, on to automatic transmission issues...making a weird noise like something is rubbing. Can't find anything externally, so I am afraid it is internal....hate transmissions! Thanks for asking though!
351Cleveland C4
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 19, 2014 07:15 AM
SC'79
May 19, 2013 04:32 PM
Kyle799
6.4L Power Stroke Diesel
Sep 9, 2012 07:00 AM
piratebronco
Jul 24, 2011 07:14 PM
Kalahnikid
Jun 4, 2011 09:22 AM
