cold start sequence
Old Feb 10, 2003 | 03:37 PM
jon1221's Avatar
jon1221
cold start sequence
I was wondering if this was normal:
Anytime I start my truck after its been sitting a while (cold start) it goes through what seems to be a warm up sequence. It idles at about 1500rpm for a minute or so and then drops to about 1000rpm for a few seconds and then back up to 1500rpm for 15 seconds or so and finally returns to normal idle range (about 500 or so). I bought my truck used and have since rebuilt the engine but its always done that. Comments??????
-Jon
'91 F-150 302 EFI 2WD Auto
4" Rancho w/RS9000
4.56 rear diff w/Auburn limited slip
Old Feb 10, 2003 | 10:06 PM
steve83's Avatar
steve83
cold start sequence
It should start at ~1200RPM, then drop to ~800. Pull the codes.
Old Feb 11, 2003 | 08:25 AM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
cold start sequence
Mine on cold start up idles to 1500 then drops down to 1000 after about 10-20 seconds and then when it is completely warm 750.
Old Feb 13, 2003 | 08:05 PM
91f250460's Avatar
91f250460
cold start sequence
Check the Idle Air Control solenoid. The procedure is in the Haynes manual. Very common for these to go out, the test is pretty simple.
