Radio and dome light quit ???
So I put a new cd player in my 76 F250 a few weeks ago and all was good. I used the factory radio ign. hot and tapped into the cig. lighter for constant power. Was working fine until last weekend I stopped and opened the door.
Radio quit and no more dome light. Checked the fuse, looked okay but I had one so I replaced it. Still no good. I have power at the fuse block so I checked the cig lighter power wire(big green and white?), none.
chased it to by the glove box where it picks up another wire and through a connector into two smaller wires, green/yellow and white/and yellow maybe. no power there. Where do those go? ANy ideas what happened?
Thanks
Thanks
fuse was blown the first time. Now the new fuse is still good, as are all the rest, but still no power.
I checked for power at the dome light, nothing. the part that i'm kind confused about is a big wire splits int two small ones. does'nt make sense to me but there's about 2 feet of harness behind the heater control and dash that I'm not sure i'm following the wire on the right end. but if i pull one end the other end moves so i figured it was the same one.
anybody know where to find good diagrams?
Last edited by ohdeere; 07-14-2010 at 07:05 PM. Reason: added a little clarification
i had the same poblem with my truck when i bought it, all my electrical was garbage and i gave up and started replaceing and re-wireing things. all in all i now have all new fuses 2 new dome light switches, all new wireing for radio, dome light, cigarette lighter, glove box light, and heater blower. i think my problem was bad conectors the previous owner did a half A$$ job of hooking up, but i didnt want to risk my truck burning up over 50 bucks worth of switches and wire
btw haynes has good diagrams
I just went to put new door jamb pins in my '79 F100. Install one on driver's side: all good. Install the passenger one: I ended up touching metal on metal which sparked and now I have no radio or dome light. Same thing - fuses all good. I did blow one but replaced it and still nothing. I'm going to see if it's possibly a fusable link, but this is very frustrating!!!!!! If anyone at all has a solution please post!
on
Thanks
Thanks
Do not use the Light Blue/Red Stripe wire to ground any Radio. It is not a ground wire, it is the Radio dial illumination wire hooked to the instrument cluster illumination. This is a very comon mistake people make, and wonder why their radio, or their instrument cluster lights quit or shorts out.
The Green/Yellow wire also goes to the fuse panel. If you blew the Radio fuse, you may have blew this fuse as well. On more modern radios both constant and ignition switched power needs to be on to make the radio work. Green/Yellow not only powers the cigar lighter, but the dome lamp switches as well.
stratsky
05-05-2016 09:33 PM
Rags1996
1983 - 2012 Ranger & B-Series
03-10-2015 12:05 PM
Blue Jeff
Electrical Systems/Wiring
03-26-2001 11:35 AM
