Gooseneeck vs. 5th Wheel?
Old Jul 13, 2010 | 07:08 PM
sumbuddyloanmea.10's Avatar
sumbuddyloanmea.10
I have a 33' 5er with a gooseneck adapter. Has worked just fine. I did this when I got the camper because my truck was already equipped with the gooseneck reversable ball.
But at times the ride on the highway seems to be quite bouncy. Nothing dangerous, just annoying at times.
So I'm wondering if the 5th wheel type plate connection provide a smoother or less bouncy ride compared to the gooseneck?
Old Jul 14, 2010 | 07:41 PM
F350 Strait's Avatar
F350 Strait
Have you thought about using air bags on the rear axle? I pull a 38' 5th wheel that can get bouncy if I don't air up the bags I put on my truck.
Old Jul 15, 2010 | 05:08 AM
senix's Avatar
senix
I have never used a gooseneck, but I do have airbags. They do help with the bounce so that maybe something to consider.
Old Jul 17, 2010 | 10:13 AM
sumbuddyloanmea.10
Airbags, eh? Which ones, and where do I get them?
Is that something you can install yourself?
Old Jul 17, 2010 | 02:02 PM
sumbuddyloanmea.10
I did some Googleing and came accross the Timbren product.
Looks like it would do the trick. Any experience?
I've read around the forum on them with not much insight.
Old Jul 17, 2010 | 08:28 PM
senix's Avatar
senix
sorry for the delay, I am traveling right now. Just east of Kansas city now. I have firestone ride rite. you can google that.
Old Aug 14, 2010 | 12:22 AM
ClydeSDale's Avatar
ClydeSDale
Usually goosenecks run higher GCWR's than fifth wheels, just another way of doing the same thing although there may be some physics involving the height of the connection that I don't understand.
I had a "chucking" (back and forth jerking) with my fifth that was REALLY annoying, especially on roads with a lot of tarred cracks. I looked at fancy hitches, etc. but ended up tucking three 60# sand bags way up front under the bed to add a couple % (from ~18% to ~20%) to the hitch weight. Doesn't bother me much anymore.
I also had a lot of spring slap since my hitch weight almost, but not quite, put me on the overloads. I added some HMWPE spring perch boosters front and rear so that when I'm hooked up I engage the overloads and I get a better ride .... so much so that my wife commented on "What did you do to the truck to make it ride so much better?" Now that's BIG points!!
Old Aug 14, 2010 | 10:20 AM
TexasRebel's Avatar
TexasRebel
a fifth wheel hitch has a much higher pivot point.
This won't make the ride any smoother, but the movement of truck and trailer will work a little better.
Another thing to look at would be a cushion hitch for your trailer.
Old Aug 20, 2010 | 11:01 PM
snorindad's Avatar
snorindad
also if necessary with a 5th wheel hitch someone can ride in the back if you have two way communication between truck and trailer. I would never do this unless it was an emergency but I do have the option.
Old Aug 22, 2010 | 07:08 AM
senix's Avatar
senix
Just be sure to check all the state laws, riding in a 5th or TT is not allowed in every state.
Two way comm's is mandatory.
