Custom Bronco Cab
Old Jul 13, 2010 | 12:23 PM
redhawk41's Avatar
redhawk41
Custom Bronco Cab
I want to put a extended cab on a bronco chassis. If that won't work I also have a regular cab to put on it. Has anyone else tried this and if so what had to be done to get it done?
Old Jul 13, 2010 | 01:08 PM
AntiHero55's Avatar
AntiHero55
are you going to have a bed on it? if so thats going to be a real small bed.....
Old Jul 13, 2010 | 01:52 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
I agree, with an extended cab, I doubt you could put a bed on it.
With a regular cab, i'm thinking it'll look like the 2010 Explorer Sport-trac
Old Jul 13, 2010 | 04:20 PM
redhawk41's Avatar
redhawk41
I am planning on about a 2 foot bed about the size of a tool box. That is not my worry. I am more worried about fitting the cab on the Bronco chassis
Old Jul 13, 2010 | 04:25 PM
dynamic's Avatar
dynamic
I beleive the bronco floor is the same as the super cab. Should fit without too many problems. Obviously you will have to move some body mounts around, but should be that big of a deal!
Old Jul 13, 2010 | 05:04 PM
Shooter00's Avatar
Shooter00
My caution would be the rear wheels and the extended cab. On the Bronco, you'll only have about 8 or 10 inches from behind the door to the front of the wheel well. It's considerable more when you look at the super cab. I don't know that it would work without cutting wheel wells into the back of the cab. Not to mention, without measuring, your entire outside bed sides would be wheel wells.
I have a 79 Bronco and Supercab sitting at the shop, next time I'm there, I'll pull some measurments and see what lines up...
Old Jul 13, 2010 | 05:40 PM
AntiHero55's Avatar
AntiHero55
someone on here has a regular cab on a bronco chassis. it has a 4` bed on it. i think theres a thread on it in the offroad forum.
Old Jul 14, 2010 | 10:32 AM
hasteranger's Avatar
hasteranger
I dont know about the bronco, but I'm thinking the rear frame rails would be too low for a bed to line up with the cab lines. we have a bronco frame laying around here and it doesn't look the same as the truck frames.
As for the supercab on a reg frame, the rear of the supercab will hit the frame where the frame arches up for the bed, so you'd have to run a body lift type deal on the supercab to space it up enough to clear the frame. Or cut into the floor of the cab.
I'm not sure what kind of issues you'd run into on the bronco frame.
Old Jul 14, 2010 | 11:24 AM
73FordF100's Avatar
73FordF100
Here's something similiar to what y'all are talking about:
Supercab on regular cab lwb chassis.
Old Jul 14, 2010 | 11:43 AM
dynamic's Avatar
dynamic
Looks like they did a good job on it! I think it would have looked better if they had moved the rear axle back a foot or two and got the axle centered under the shortened bed.
Old Jul 14, 2010 | 12:00 PM
73FordF100's Avatar
73FordF100
Yeah it looks like it! It looks like a Japanese extended cab truck with the rear axle being where it is.
Old Jul 14, 2010 | 01:38 PM
hasteranger
In my opinion that is one ugly little truck.
Old Jul 14, 2010 | 02:02 PM
73FordF100's Avatar
73FordF100
Yeah I don't really like it either.
Old Jul 14, 2010 | 02:32 PM
81-F-150-Explorer
Well the supercab wont work without cutting wheel wells into the cab.
If that truck pictured is a super cab on a regular longbed wheel base frame...
The bronco wheelbase is even shorter than the regular shortbed wheelbase frame.
Old Jul 14, 2010 | 02:38 PM
73FordF100's Avatar
73FordF100
Yep there's definitely gonna be some issues.
