Getting 12V at the ignition coil with resistor wire installed
Old Jul 18, 2010 | 12:10 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by JimKoz
You did check the voltage while the points were closed, right? If the points are open, you'll always have 12V at the coil because there isn't any current flowing in the circuit, and you won't have any I X R drop across the resistor wire.
Exactly
Old Jul 18, 2010 | 12:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by carprojects
I am debugging my electrical gremlins and found that I burned up a new coil that required an external resistor. I checked the voltage at the coil and indeed have 12.3 Volts. The odd thing is that it runs through the resistor wire and I've checked for shorts and other connections and everything is wired correctly.
The resistor wire only measures 2 ohm, so it doesn't seem to have too much resistance. It is the original wire so perhaps it's changed over time??
What voltage should I be getting at the coil?
Should I just run a coil with internal resistor and remove the resistor wire?
I was told that you should get 12V at the '+' side of the coil and 11 V at the distributor side, or '-' side, but I have never heard this before.
As original, fits all 1960/72 Passenger Cars, Trucks, Bronco's & Econolines.
COLF12250A .. Resistor Wire-Ignition Coil (Motorcraft DY37).
61.49" long / 1.30-1.40 ohms resistance / Color coded PINK / #20 gauge wire.
Old Jul 18, 2010 | 01:02 PM
carprojects's Avatar
carprojects
OK, I figured it out !!!!!!
I hadn't checked the gap in a while and when I did, the gap in the points was way too large, so it wasn't closing fully, hence I think the reason it was showing 12V all the time. I reduced the clearance and am now getting 9.7 V on the + side. I am going to leave in the ballast resistor. Thanks to everyone who helped.
whisler
126
Jul 18, 2017 07:50 PM
mountain dewd
40
Apr 30, 2016 10:33 AM
ihcc104
Apr 16, 2016 08:13 PM
Delta Dirt
Aug 26, 2013 08:56 PM
eficat
Jul 29, 2011 09:00 PM
