EBPV problems
Old Jul 13, 2010 | 11:31 AM
plgebbia's Avatar
plgebbia
EBPV problems
The EBPV is sticking in another truck I've got and it is also leaking oil at the actuator rod. It is my plan to remove the part of the turbo that clamps to the DP, take out the butterfly valve and plug the hole. then gut the actuator and put a plug in the rod hole. Can all this be done with the turbo in the truck? and am I missing any part of the procedure? Thanks everyone!
Old Jul 13, 2010 | 11:46 AM
redman84's Avatar
redman84
Who did the delete to your truck? Or did you do it with the motor out? Sorry that I have questions instead of answers. Hopefully you can leave the turbo in because I'd really like to get that dang thing out of mine.
Old Jul 13, 2010 | 11:52 AM
plgebbia's Avatar
plgebbia
I did the delete in my truck, but the motor was out at the time, and My actuator is still hooked up(it wasn't leaking) I just took out the butterfly valve.
Old Jul 13, 2010 | 12:16 PM
Talyn's Avatar
Talyn
you can do it with it in the truck, but you'll get metal shavings in the actuator rod cylinder.
Best to remove it and just cut it off and get it welded. Be done with it.
If you cannot get it welded. you can just pull the plunger out and cap the hole with a pipe thread plug after taping it.
I haven't finished my article yet. otherwise I'd try and show more of whats going on.
With the actuator housing out of the way, the turbo can be removed without any effort.
and reinstalled. I can get mine out in about 20 mins.
Old Jul 13, 2010 | 01:43 PM
jchosler's Avatar
jchosler
I'll do my delete when your article is done, something I've been meaning to do.
What welding process is used?
Old Jul 13, 2010 | 02:18 PM
plgebbia's Avatar
plgebbia
Thanks Talyn, I just went and looked the problem over and I noticed that one of the wires going to the turb was bare and it was shorting out on the intake plenom, causing the EBPV to stay shut. I may take the turbo off and mod the pedastal like you say, if it makes the turbo that easy to get off!
Old Jul 13, 2010 | 02:31 PM
jwhitetail's Avatar
jwhitetail
The EBPV is a recticition to the exhaust flow get rid of the Ford EBPV and get a Banks Power Elbow and don't look back. JMOP
Old Jul 13, 2010 | 10:15 PM
Talyn's Avatar
Talyn
Why would you buy an overpriced banks product that doesn't do anything new?
No offense to your thought there,
but you just gut out the EPVB, throw in a freeze plug and your done.
You have to have the pedestal tig welded.
I got mine done for 20 dollars.
xbox73
May 5, 2014 06:47 PM
fleonardis
Mar 16, 2013 07:16 PM
RMBC Freeride
Oct 10, 2009 10:51 PM
beebesean
May 19, 2008 07:33 PM
Goober1979
Apr 6, 2007 11:43 AM
