Diesel Leak
Old Feb 10, 2003 | 11:30 AM
Byron 79424's Avatar
Byron 79424
Question Diesel Leak
I am experencing diesel leaking from what looks like the injector pump area on top of motor. This only happens when temp falls below 32 degrees. This is on a 99 F-250 Super Duty Power Stroke.
Hope ypu guyys or gals out there have an answer.
Old Feb 14, 2003 | 09:17 PM
E350Racebus's Avatar
E350Racebus
Diesel Leak
I just fixed a similar problem with my E350....It ended up that it was leaking from a small hole on the bottom of the fuel pump. I'm not sure if this hole is supposed to leak when the fuel pump is going bad(like a water pump). There are 3 hoses that go from the fuel pump to the fuel filter housing(If my '97 is the same as yours). I would check these first if I were you.
Good luck
