best carb for a 302?
Old Jul 12, 2010 | 08:19 PM
cjohn2000's Avatar
cjohn2000
I have a 1983 f-150 w/ 302. My question is is what is the best carb for a 302? Right now its got a little motorcraft carb w/ all sorts of vacuum tubes and electric choke. Iam a landscaper and occasionally haul around dirt and so forth but no towing. Im looking to get better gas mileage because now i only get 11.6 in town. Is manual choke better? Any help appreciated.
Old Jul 12, 2010 | 08:39 PM
Franklin2's Avatar
Franklin2
I like manual choke Holley 600 cfm carbs for the 302. I have used this setup on a couple of 302's I had, and always had good service. I like the manual choke because there is no fuss with adjusting it like the automatic style, and they are cheaper than one with a automatic choke.
Old Jul 13, 2010 | 04:58 AM
Old Hickory's Avatar
Old Hickory
I would reccomend that you rebuild your original carb. If your truck is stock and you use
it as you say I think this would give you the best result. If you change to a different
type carb you are going to have to do some engineering and tuning to get it to work.
Old Jul 13, 2010 | 11:07 AM
cjohn2000's Avatar
cjohn2000
Somewhere i heard that when the power valves? start to leak they drink fuel but all the vacuum tubes between the snorkel and carb really intimidate me. Do they make a kit to go to manual choke?
oft
Oct 31, 2014 02:03 AM
gtuttle
May 27, 2010 08:15 PM
amory
Jan 19, 2009 05:36 PM
bronco-man
Jan 30, 2008 09:31 PM
danimal
Feb 25, 2004 10:36 AM
