To be honest I didn't come across that problem... This was my modification and it works. Pretty good. I had to put 2-4 inch lift shocks. Which was around 140$ and about 40$ in the steel plates and grade 8 extended bolts. That spacers I made myself at work.
Looks good. Any side shots? Before and after? Maybe because it is street driven and the travel is minimal, you aren't experiencing bump steer, but with a wide range of travel, it would seem to me that you would have toe in/out through out the range of suspension cycling.
I have a 2wd f100 and instead of flipping the axle, I put 4 inch lift springs on it that a freind gave me. After i put them on my camber was way off. So i made drop brackets out of 1/4 steel to drop the pivot point of the i beam down 4 inches. i bolted it on and made a brace for each side that goes from the drop bracket to the crossmember. This could be easier than what you are doing but I've never flipped a axle so i wouldn't now. I ended up with 4 inches of lift for free.
Exactly what I did about 10 years ago when I had this '77 shortbed, those are 33s of 10" wheels
Haven't. And probably wont do the flip, SS per the guys that have done it, it may be more of an off road doing than for a daily or a tower. A dropped pitman arm would do the trick though. . I think I am going with new slightly longer coils just to clear the 33"s and level the truck.
Originally Posted by teds74ford
When you drop the pivot, you need to drop the pitman arm to avoid bump steer. How are you guys addressing that?
When you lift a 2 wheel drive for off roading you just give yourself that much more height to get stuck.Now before anyone gets all bent out of shape, I have owned 2 wheel drives with lockers. They did very well in sand, but it is still only 2 wd. Cant compare to 4x4 doesnt matter what you do to them.
eh, guys with 2wds need to be or ARE better drivers
In reality though it's all about the type of wheeling you want to do. Out here in the deserts, 2wds do just fine. Now for a rock donkey or mud truck, yeah, you may need 4wd.
I'm not sure the guys doing this understand what bump steer is...
For a street driven truck with not a ton of travel like these look to be - it wouldn't be a major issue.
Even with a drop pitman arm on a long travel truck the bump steer is there. It takes a lot of work to get rid of it even with a single or dual swinger setup.
