Camber problem
Old Jul 11, 2010 | 11:31 PM
ExtrmZ's Avatar
ExtrmZ
Camber problem
Does anyone have problems with massive negative camber while in reverse? it happened before, and i just finished my 4in lift and backing out of the garage i left two skidmarks, from the side of the tire only being on the ground.
anyone know what would cause this?
Old Jul 12, 2010 | 12:53 AM
86F150302's Avatar
86F150302
A little is normal with the suspensions on these trucks but skid marks is a little to much.
Radius arm bushings okay?
Replace bushings if bad or looking bad and go get an alignment.
Old Jul 12, 2010 | 05:34 AM
jplinville's Avatar
jplinville
Massive amounts of camber is not right. I'm thinking that there is other issues to address with the truck.
Old Jul 12, 2010 | 06:40 PM
kunkle77's Avatar
kunkle77
had the same problem but i only installed a 2 inch leveling kit. just go to your local parts store and get Camber kits should fix it
Old Jul 12, 2010 | 07:10 PM
capn kirk's Avatar
capn kirk
jack it up, do some shakin, and you'll probably find somethings good n loose
