Three crazy questions.
Old Jul 11, 2010 | 10:43 PM
flipklos's Avatar
flipklos
We are working on a 1996, SWB, F150, 2WD, 4.9, M5OD.
1) Bank 1/Sensor 1. That is the front manifolds O2 sensor correct?
2) Does ford still sell the service manual for the 96 F serries?
3) I got a real odd cavitating sound that occurs after full clutch engagement in 1,2, and 3rd gear on hard acceleration. Sounds like a fan draging on the radiator but lower in note. No dammage to the fan, shroud, or radiator. I got the factory U joints still. I think I will try replacing them as they got 86k on them. I checked them but they feel good and tight. My next guess is throwout bearing which is quiet at all other times sooooooooo?
Old Jul 11, 2010 | 11:05 PM
lupin398's Avatar
lupin398
It could be very well possible that your water pump bearing is going out, and it's nicer to have a new one in there then to have one critically fail at speed.
Old Jul 11, 2010 | 11:48 PM
ichabod40's Avatar
ichabod40
If your ford parts house doesn't have the factory service manual, you should be able to get it through: Service Manuals, Owner Manuals, Wiring Diagrams, Service Bulletins - Helm Incorporated
Old Jul 12, 2010 | 12:04 AM
94MustangGT's Avatar
94MustangGT
1. Don't know.
2. Ford, Chiltons, and/or Hayes should.
3. Does the shifter vibrate more than usual? What you describe almost sounds like what happened on my car when the harmonic balancer went bad. Just a thought.
Old Jul 12, 2010 | 12:14 AM
flipklos's Avatar
flipklos
Sounds undernneth the vehicle so I doubt a waterpump bearing. I will check however. It is an idea.
No, the stick and engine suffer no unusual vibrations that I notice. I have had 2 fulie and 2 carbed 300s so I know the feel of them. Will check that too when I pull the belt.
I have owned a haynes for the past 7 years for these trucks. Though useful I am starting to outgrow it. I have a reputation of being a great diagnostician. Albeit one of the slowest SOBs you will ever meet. I hate buying un-needed parts.
No idea on which sensor that is?
Old Jul 12, 2010 | 07:59 AM
Conanski's Avatar
Conanski
That truck should have 3 sensors BTW, and bank1/sensor1 is the front one on the passenger side.
