New air filter and truck dies?
[COLOR=black][FONT=Verdana]I just changed my filter element and now my truck dies randomly. If I put the old filter back in it runs fine. When it dies it just shuts down. The filter is the PowerStroke Air Induction System. It ran great until I put in the new filter. After install I drove twenty feet and it died. It starts right up after it shuts down. After about ten miles of driving and shutting down I put the old filter back in and it ran fine. Thank god I put the old filter in the cab for some reason instead of the garbage.
<o></o>
Early 99 f250<o></o>
246,300 miles<o></o>
No chip or tuners<o></o>
Straight piped<o></o>
All stock except for the removed cat and muffler
Thanks in advance
Chad<o></o>
<o></o>
Thanks in advance
Chad<o></o>
It’s got me scratching my head for sure. I just did a test run and made it a block with the new filter in and it died. Swapped back to the old one and no problems, went five miles and no problems. With the new filter it will die just idling as well, and by just shifting through the gears. Old filter and it runs great??????????<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old air filter is not completely plug up.
Put in new filter and instant problems.
Is it one of these: AMSOIL - 7.3L PowerStroke Air Induction System. I would of went for a ford ais (http://www.riffraffdiesel.com/mm5/me...gory_Code=sale). I don't know why it says recommended for stock trucks only. Do you have any mods. Maybe that filter is to restrictive but that would be hard to believe.
Yes that is the filter I have. I have the blue ford one, not the white amsoil one. Had a white one but never noticed any difference. the only difference was cost. No shrink wrap on filter. Never have had a problem when changing before.
The only mods I have done is remove the cat and muffler, stock size exhaust pipe.
I put in new filter shuts down almost instant. Put in old filter and not a problem
Oil was changed with in the last month, along with fuel filter.
I put in new air filter and instant problems.
I unhooked the batteries over night in hopes computer would reset if that is possible.
Kicks no codes
Service engine light comes on when it shuts down.
Since I have owned the truck parts that have been replaced. Small list
Picked up with 90,000 miles.
1 alternator
1 water pump
new front hubs
Ball joints
Routine maintence, oil, fuel filters, brakes, tranny service, front and rear end services, etc.........
Kicks no codes
1 alternator
1 water pump
new front hubs
Ball joints
The only way an air filter will affect how an engine runs is if it gets enough air or not. I don't think your new filter is related to your truck shutting down, unless it's completely blocking any air from getting to your engine. Or you're bumping a sensor everytime you change the filter.
Something's not making sense.
Where are you located, maybe there's someone close by that can help you diagnose your problems. Do you have access to a code reader, see if any codes have been thrown?
The new filter is fine. Its got to be a senser. I ducked tapped the air box intake hole down to about one thrid of the original size. No problems with it shutting down. Just wasnt getting enough air if I gave her a little. Bogged her down. Cut it open to about 3/4 of actuall size and it shut down.
Something is not happy with the amount of air its getting.
Thanks to all for the help so far.
No just did it this afternoon. With the old filter it runs fine. So I restricted the air with the new one and it ran fine. Something on this thing doesn’t like the amount of air it’s getting. It was an experiment. The old filter is around 70%. Decided to switch now cause the next few months going to be in some nasty dusty conditions.
Ding ding ding we have a winner. You are probably going to want to scan that truck for codes or log some variables like your manifold gauge pressure when this happens. There is no other sensor that cares about intake pressure or vacuum before the turbo.
