Computer Chips & Tuners
existing programmer
Old Jul 10, 2010 | 10:27 PM
SoArkSI's Avatar
SoArkSI
existing programmer
I usually deal with my 77 4x4, but my wife has an 05 1/2 dodge ram 4x4 and she wantd to lift and change the tires and wheels also. I wanted a programmer for the upgrades, but mainly for speedo changes. My question is (truck was bought used) how do I put a programmer on my truck when their might be one on it already?????? If so how do I erase it all to stock and start over. Thanks for any replies.
Old Jul 11, 2010 | 04:58 AM
shotgunz's Avatar
shotgunz
I'll assume you do not have access to the programmer. If you did, the easiest way to get back to stock (which is critical to installing a new tune), is to use the programmer to flash the truck back to stock.
Take it to the Fiat, I mean Dodge dealer and have them read the calibration. If it's non-stock, have them re-flash it.
Even if it is stock, you may want them to reflash it anyway (to make sure you have the lastest).
Then you should be able to install a canned or custom tune.
Old Jul 11, 2010 | 08:43 AM
tex25025's Avatar
tex25025
I would check the dodge coverage, but I do know AE with regard to the 6.0s can recalibrate the speedo for larger tires, plus you get a whole lot of diagnostic abilities that would supercede that of the programmer. AE with a dodge coverage(it won't work on your 77, has to be OBD-II on up) will probably set you back the same price as a programmer, but unless you are wanting the extra power as well, AE gives you a lot of tools to do your DIYer stuff yourself. A budget way of getting near dealership coverage(atleast with the 6.0s).
This way it shouldn't matter rather or not you already have a stock flash or a non-stock flash, however, AE will also let you know what the strategy is and if you have a list of stock strategies then you could determine it yourself. I think a dealership would charge you both for the initial hookup to find out if it's stock and for flashing your vehicle as I would imagine an 05 would be out of warranty for a gasser by now.
I will add this, depending on how high the lift is for a gasser 1/2 ton, you might want to also think about gear changes as well. Might want to go lower with the gearing, I have a feeling that will help you out more then the tuning alone would be able to do.
Old Jul 11, 2010 | 09:36 AM
SoArkSI's Avatar
SoArkSI
thanks for the replies! I will prolly let the dealership reset all funtions to stock that way I Know that I am starting stock ecu. I knew my ford brothers (sisters too) would pull together and help me figure this out. The dodge website I went to was really no help. I will keep you up on info when we get that far on the build.
