Anodized Aluminum Trim
Old Jul 10, 2010 | 08:24 AM
torpedo tom's Avatar
torpedo tom
Can anodized trim parts be polished? I was told a few years ago that you ran the risk of burning them if you tried to polish them. I didn't know if they have come out with a new process for polishing.
Old Jul 10, 2010 | 08:30 AM
65jim's Avatar
65jim
Yes you can Tom,but you have to remove the anodize first.jim
Old Jul 10, 2010 | 09:18 AM
daveengelson's Avatar
daveengelson
Understand the trim, grille, headlight, turnsignal covers, etc., are of a low grade alloy alum and plated with a thin coat of anodize; once the alum is exposed it can oxidize, or blacken within short period of time then requires regular attn. Don't suggest using a buffing for reasons mentioned. Perhaps wash with mild soap then apply very mild compound using soft cloth. Few years ago recondition the grille on the 65; anodize remover, sanded, polished, then applied coat of clear, found it very labor intensive and appears about time to redo.
Old Jul 11, 2010 | 07:07 PM
torpedo tom
Thanks for the input. May just install my painted grillor have it chromed. Thanks again. TT
Old Jul 11, 2010 | 10:16 PM
Boss9F100's Avatar
Boss9F100
yes they can be buffed to a point. I use an air buffer with a foam pad and automotive rubbing compound. That will brighten them somewhat.
As others have said in order to get a nice shine the anodizing needs to be stripped, aluminum polished and re-anodized or cleared.
Redagain
Nov 6, 2016 08:18 AM
tkmitchell
Jun 14, 2016 11:40 AM
66F100Again
19
Feb 4, 2011 08:59 PM
Diesel_Brad
75
Dec 18, 2009 07:11 PM
bluestang65
Nov 17, 2008 08:42 AM
