I've had kind of a tranny issue lately. Every once in awhile when I shift my truck into D there is a long delay. I can rev the engine and it will finally engage. It doesn't happen everytime, just sometimes. I have noticed if I shift into L it will engage quicker.
I took the advice from an earlier post adn checked the bolts under the dash and found them loose. I tightened them and the shifter is a lot tighter, but the shift problem is still there.
This has started happening only since I had the torque converter replaced and a shift kit installed.
