Help 460 wont start
Old Jul 9, 2010 | 12:00 PM
Andrew460's Avatar
Andrew460
Help 460 wont start
Im New here and Im Looking for some help with a 1996 F-250 with a 7.5, 4speed w/creeper It starts fine when the engine is cold but when you get the engine hot and shut it off and set for 15 mins ,when you restart it it runs for a couple of seconds and quits have to hold pedal to the floor for it to restart. Checked fuel psi (35-40) and changed cap, plugs and wires. Also noticed that it is running about the M in normal on the temp gauge, another problem is when driving down the road it wont hold its self back when you let off the pedal to slow down unless you lightly touch the clutch pedal. its gotten worse since its been hot out. any ideas?? Thanks
