timing
Old Jul 8, 2010 | 04:34 PM
SmallBlockV8's Avatar
SmallBlockV8
timing
What degree of timing makes the most power on a 302 motor from 1982
Old Jul 8, 2010 | 05:46 PM
Franklin2's Avatar
Franklin2
Each combination is different. As a general rule, the more advanced you make it, the more power it will make, till it starts pinging, or won't start hot.
So get a timing light and see where you are at now.
Advance it a couple of degrees and take it for a test spin. Leave it in high gear and pull a good hill with it. If it doesn't ping, come back and advance it a little bit more.
Keep doing this till it starts pinging. Then back the timing off till it quits pinging.
After all this, shut the engine down(should be good and hot) and let it sit for 2 or 3 minutes, and then try to start it. If the starter struggles, then turn the timing back a little bit till the starter spins the engine without struggling to turn it over.
That will be your best timing point.
