carb linkage
Old Feb 9, 2003 | 04:43 PM
dwayne93's Avatar
dwayne93
Question carb linkage
i need assistance in locating a pictoral of the carb/gas pedal linkage under the hood. the truck has been worked on previously, and i belive that some of the parts my be missing. i.e. return spring, linkage rod?
the truck in question is a 1967 f 100
300 six cyl.
3 speed on tree
if you have a picture that you could email me or direct me to a manual that has a picture thanks for amy help
Old Feb 11, 2003 | 08:32 AM
fordxxx's Avatar
fordxxx
carb linkage
I don't have any pictures of your carb linkage but I have a '72 with a 302 that came with a very complicated series of levers and linkages including a link to the firewall. I was alway playing around with it and never sure if I was getting wide open throttle when I floored it. The later trucks, like the '74 I found, have a single link between the gas pedal lever and the carb. I took all that other junk off and replaced it with the '74 setup and it works much better. Maybe you could do the same.
