quick injector question
Old Jul 8, 2010 | 09:34 AM
JoeyB94's Avatar
JoeyB94
Im ordering up injectors tonight from Pensacola. I have a 92 7.3l with the zf5 in my f350. I dont have a turbo yet but within the next year Ill be getting one hopefully. Should I get turbo injectors for the truck or just the regular ones for now? The turbo ones say they are for 93/94 trucks only, or this just because thats the only 2 years they had turbos?
Old Jul 8, 2010 | 09:47 AM
starmilt's Avatar
starmilt
Yep. The way I understand the g code injectors for the turboed motors were a little different for emissions. Everybody uses the b code injectors to replace them without any problems.
Just a suggestion buy new ones instead of rebuilt for the difference in price. I would check the price difference of the new ones and the matched ones from someone like type4 too.
Old Jul 8, 2010 | 10:09 AM
wreckinball's Avatar
wreckinball
no kidding, the price diff between new and rebuilt is negligible at best. Typ4's always have great results but are a lot more so if you cant go with them get the new ones from pcola diesel. Injectors new from them will be the same from anywhere else, now their injection pumps are a different story.
Old Jul 8, 2010 | 10:48 AM
JoeyB94's Avatar
JoeyB94
I gotta use paypal and Im on a very tight budget otherwise I would get the matched ones. So should I get these?
Pensacola Fuel Injection | Worlds #1 Diesel Rebuilder - FORD 6.9L - 7.3L :: INJECTORS :: SET OF 8..84-1993 6.9-7.3 NEW Delphi Injectors (No Cores)
Old Jul 8, 2010 | 10:52 AM
wreckinball
those are the ones!
Old Jul 8, 2010 | 10:58 AM
JoeyB94's Avatar
JoeyB94
ok thanks. Im gonna order up a return line kit too.
Old Jul 8, 2010 | 11:36 AM
starmilt's Avatar
starmilt
Do yourself a favor and get some viton orings while your at it, they are very cheap and well worth it with this fuel nowadays.
Old Jul 8, 2010 | 10:45 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I also recommend tossing the o-rings in the kit for these Viton Return O-Rings - McMaster-Carr Item 9464K24, Viton is impervious to Diesel.
I also found most o-rings in the kits I just got from Pensacola with flashing issues, caps were nice, no flashing at all, the hose is ok, it is cloth wrapped but it's not good German hose and the spring clamps are cheap, not good German ones but I suspect they'll be just fine as long as they don't get over stretched, I'll know tomorrow after I'm done installing one of the kits.
-Enjoy
fh : )_~
Old Jul 10, 2010 | 11:53 AM
JoeyB94's Avatar
JoeyB94
I just ordered ethe viton o rings. Thanks for all the help guys.
Old Jul 14, 2010 | 01:42 PM
JoeyB94's Avatar
JoeyB94
I got all my parts today. The returnline kit came with plastic ts instead of the metal ones that are on the truck now are metal. Are the pastic ones ok or should I reuse the metal ones? Also what am I putting the vasoline on? the viton rings right? Any other helpful hits are appreciated.
Old Jul 14, 2010 | 01:53 PM
starmilt's Avatar
starmilt
If you have metal T's you could get a fortune for them, as I have never seen an idi with anything but plastic. If yours are gray they are original and I would take a close look at them as I belive they are better quality than what comes in the kits nowadays.
Old Jul 14, 2010 | 02:35 PM
Festus Hagen
Methanoholic
Yes, use Vaseline on the o-rings.
-Enjoy
fh : )_~
Old Jul 14, 2010 | 04:21 PM
JoeyB94's Avatar
JoeyB94
I think I'm gonna see what kind of shape the metal t's are in and reuse them if I can since they seem like they would be durable compared to the plastic ones. I almost forgot one more thing, Im also changing the fuel filter while Im doing this since mine was pretty old. I know I gotta filll it before I put it on, but do I got to bleed the injectors also since Im replacing them and if so how do I do it lol?
Old Jul 14, 2010 | 04:29 PM
Rick Wallace's Avatar
Rick Wallace
Nope................BTW I love your avitar!!
Old Jul 14, 2010 | 04:30 PM
Festus Hagen
Methanoholic
I and I'm sure others would love to see a picture of them metal tees ...
Are you sure they are metal and not just painted plastic??
If they are metal they are custom made.
If they are metal I would reuse them as well!
-Enjoy
fh : )_~
