closed loop
Old Jul 8, 2010 | 08:11 AM
mrcassidy95's Avatar
mrcassidy95
closed loop
86 f250 5.0 efi is there an easy of verifying the truck is going in to closed loop
thanks
Cassidy
Old Jul 8, 2010 | 09:03 AM
Franklin2's Avatar
Franklin2
Check the codes from the computer. If you have no codes, you are going into closed loop, since this is what the computer tries to achieve each time the engine is fully warmed up. If for instance you have a oxygen sensor code, you are not going into closed loop since this is the main sensor for that mode of operation.
